Kid, Shunt, Whizbang Jr. and Battery Tender
Zakarume
Solar Expert Posts: 143 ✭✭
I dont know if i can do this or if this dangerous.
Can i wire the Negative wire from Battery Tender to the Shunt so my Whizbang Jr and Kid can see how much power along with solar comes in?
1460 Watts Solar @24v. 675 AH Battery Bank using 12 6v Trojan T-105. 1 Midnite Classic 150. 1500 Watt 24v Samlex Pure Sine Inverter
Re: Kid, Shunt, Whizbang Jr. and Battery Tender
Yes.
The WhizBang Jr. doesn't care about the source of the charging current, it just reports what's going across the shunt to the charge controller. It can measure power from any source on the correct side of the shunt. -
Cool Thank You again1460 Watts Solar @24v. 675 AH Battery Bank using 12 6v Trojan T-105. 1 Midnite Classic 150. 1500 Watt 24v Samlex Pure Sine Inverter
- 230 Forum & Website
