New to solar
oadkins
Registered Users Posts: 19 ✭✭
What is the best way to install Honda ie2000 inverter gen set with a 45 amp converter charger to 12 volt battery bank 600 amp with 1kw solar panels . Thank You
Re: New to solar
Wires?
Really; I don't understand what you're asking. For instance what exactly do you mean by "45 Amp converter charger"? An Iota 45 Amp 12 Volt battery charger? Other RV based converter? Something else?
As far as it goes the gen puts out 120 VAC, the charger plugs into it, and the DC output from the charger goes to the batteries. The solar panels don't really enter into the equation.
- 232 Forum & Website
