solar inverter poblem
g.ramesh
Registered Users Posts: 1
Re: solar inverter poblem
Welcome to the forum.
I can see that English is not your first language, but we really need more details about the situation in order to suggest a solution.
1). Is this a grid-tie or an off-grid system?
2). The current is not showing on what circuit? Panels to GT inverter? Or inverter output to system wiring? If off-grid: Panels to charge controller? Controller to batteries? Batteries to inverter?
3). What was the old inverter and its specifications? What is the new inverter and its specifications?
Unfortunately there is quite a wide variety of equipment out there. The problem can be anything from accidental reversal of the (+) and (-) input to a GTI to the new inverter not operating at the same input (or output) Voltage as the old one.
