SOLAR 2007
crewzer
Registered Users, Solar Expert Posts: 1,832 ✭✭✭✭
This year’s National Solar Energy Conference, SOLAR 2007, will take place July 7-12, 2007, at the Cleveland Convention Center in Cleveland, Ohio. See: http://www.ases.org/solar2007/
Here’s a link to the confirmed exhibitors list: http://www.ases.org/solar2007/exhibit/confirmed.htm
HTH,
Jim / crewzer
HTH,
Jim / crewzer
Re: SOLAR 2007
hmmm. i find it interesting not just by who is going to be there, but also by who isn't. -
Re: SOLAR 2007
Are there any major Solar conferences planned for SE Arizona this or next year?Ranch Off Grid System & Custom Home: 2 x pair stacked Schneider XW 5548+ Plus inverters (4), 2 x Schneider MPPT 80-600 Charge Controllers, 2 Xanbus AGS Generator Start and Air Extraction System Controllers, 64 Trojan L16 REB 6v 375 AH Flooded Cel Batteries w/Water Miser Caps, 44 x 185 Sharp Solar Panels, Cummins Onan RS20 KW Propane Water Cooled Genset, ICF Custom House Construction, all appliances, Central A/C, 2 x High Efficiency Variable Speed three ton Central A/C 220v compressors, 2 x Propane furnaces, 2 x Variable Speed Air Handlers, 2 x HD WiFi HVAC Zoned System Controllers -
Re: SOLAR 2007hmmm. i find it interesting not just by who is going to be there, but also by who isn't.
That is always the most interesting part of those :roll:
