GVFX sell settings recommendations
Re: GVFX sell settings recommendations
I may have misunderstood. I wasn't told one way or the other but I have seen complaints before on the outback web site where people had sent their mate in and had gotten a beat up replacement.
gww -
I was happy that a nine year old inverter could still have parts bought and replaced so easily, if not cheaply, compared to having to replace the inverter. I didn't even think to ask one way or the other. I do agree they should tell you.
Good luck.
gww -
Re: GVFX sell settings recommendationsI was happy that a nine year old inverter could still have parts bought and replaced so easily, if not cheaply, compared to having to replace the inverter. I didn't even think to ask one way or the other. I do agree they should tell you.
Good luck.
gww
For one thing, you can still buy an Outback GVFX3648: http://www.solar-electric.com/inverters-controllers-accessories/gridtiesolar/oupogrsiwain/outback-power-60hz-grid-interactive-inverters/outback-power-grid-interactive-sinewave-inverter-gvfx3648.html
The design is relatively unchanged since they were first introduced, and that certainly helps with the replacement parts.
Those Gudgel boys knew what they were doing even back then. -
Gww. Do you use the sell function with your inverters? If you do, how do you have them programmed as far as the voltage set point that dictates when sell begins? -
verdigo
I have never used the sell except for 5 min to see what it was like. I have read a bunch of discussions on it before I installed my system but will be danged if I can remember what I read. I do remember where I read them though.
http://outbackpower.com/forum/index.php?sid=2f1ec936ec7eb584c9f67f32b723e85a
Maby read some of the old grid tie post or do a search. I only have medeoker luck with search.
I hope this helps.
gww
