Outback FX inverter auto starting a Honda EU3000i
Ronray
Registered Users Posts: 2 ✭
Hello,
I have a client with an Outback FX 2524T and DC Flex net. They want to start a Honda EU 3000i using the 12volt Omron relay and socket purchased at NAWS. Has anyone had experience with installing this? I am lost on this one. I have downloaded the Honda owners manual with wiring diagram for reference. Wondering also if this relay can shut down the generator after it is running.
Thanks Ron
Thanks Ron
Re: Outback FX inverter auto starting a Honda EU3000i
From a couple of years ago, one of our members found this from Magnum on running a Honda eu3000i with their controllers:TheBackRoads wrote: »
In general, Honda's seem to need to run the choke to start reliably--You may have to figure out an auto choke solution. You may talk with Central Main Diesel:Dave Angelini wrote: »At less than 60 decibels the Honda inverter line is hard to beat. I would hate to live near someone with a loud generator. I pretty much use this for all the homes that need 240vac. The 3000 i would be good also. These folks in Maine have been very reliable for me. I would address all of Bill's concerns also. Fires are bad with unattended operation!
http://www.generatorsales.com/order/Honda-EU6500iSA-Tri-fuel.asp?page=EU6500iSA_Tri_Fuel
