New PVWatts Data
jebatty
jebatty Solar Expert Posts: 56
PVWatts has new data as of 09/08/2014. The prior data set for me was from a point 92 miles away; the current set is from 1 mile away. Much more accurate representation of my actual experience. The new data also deleted a point 46 miles away.
    Re: New PVWatts Data
    What PV Watts link/address are you using now?
  • Vic
    The Link in this post still seems to work. Appears that PVWatts1, and 2 have been supplanted by the new version:
    http://forum.solar-electric.com/showthread.php?23132-NREL-PVWatts-New-Beta-Version-dtd-March-2014
    FWIW, Vic
    OK, it is here (thanks Vic):
    http://pvwatts.nrel.gov/pvwatts.php
    Lots more data sources, "prettier" user interface, more of a pain to cut and paste results into posts (:cry:) when answering questions...
  • Vic
    In the Beta version, the added data in the Geographic Data set is a help. But for each scenario, using the same location data, but with differing PV data, one would need to enter a solution for a new graphic riddle EDIT: -- CAPTCHA -- This made things a bit tedious.
    Have not used the non-Beta version, so cannot say if this feature still exists.
    BUT, still, this is an excellent service from the US Government, IMO. FWIW, Vic
  • gww1
    gww1 Solar Expert Posts: 963 ✭✭
    As pv watts is defaulted for grid tie, would I put 48% for as the devalue rather then 15% they have listed? The closest location to me is still 54 miles away.
    Putting 48% devalue came up close to my actual production.
    gww
    Old pvwatts was 77% efficiency, or 13% derating
    Our off grid 52% efficiency or 48% derating.
  • gww1
    Thanks Bill,
    gww
  • zoneblue
    My understanding is that for mainland us, the old versions of pv watts used land based weather station data. The newer ones uses satelite data and hence is finer grained. They claim a 10km grid.
    See http://pvwatts.nrel.gov/version_5.php
