Canadian Solar brand panels?
KE5YD
Solar Expert Posts: 32 ✭✭
Any history or knowledge about the CS6P255 panels? I can buy these locally and save shipping. I know the China/Canadian
relationship. Just checking? Not what I had in mind but..............Appreciate any comments.
Re: Canadian Solar brand panels?
I've installed more Canadian Solar than anything else. Never a problem. They did change the junction box design a while back which made the effective length of the leads a little shorter which precludes doing our favorite "skip" wiring technique. Am using ET-Solar now. -
I bought this brand . Put my order in a while back with a few other "Great White Northern " types .
We wanted thicker glass for snow load/hail , since our weather is getting funky . They are what was purchased. 305W mono .
VT -
Excellent Panels.
Amongst the best out there. Very efficient and tolerate heat well. Very satisfied with the ones I have.
A friend of mine just installed 11 of the 310w Poly CS6x-Maxpower ones and gets 20KWH/day out of them in September! -
Very pleased with the ones I have. Very well made. Wish all my panels were Canadian Solar! -
Re: Canadian Solar brand panels?I've installed more Canadian Solar than anything else. Never a problem. They did change the junction box design a while back which made the effective length of the leads a little shorter which precludes doing our favorite "skip" wiring technique. Am using ET-Solar now.
I just used the 310 watt in project and the leads were long enough if the panels were in a straight line, as one would in commercial or or horizontal tracking.
Really nice panels but not quite excellent in efficiency, very close to the Sunpower and Panasonic."we go where power lines don't" Sierra Nevada mountain area
I installed 12 of the 250 watt panels and they all delaminated. Canadian Solar was very good about handling the RMA and getting 12 new panels out but said do to the anti dumping laws they could not send me the same size panels so I have 240 watt panels coming to replace the defective ones. -
Thanks! for your comments......I went ahead and purchased some...we'll see?
