MTTP controller sez "overcharge" (some times )
uncledave
uncledave Registered Users Posts: 4
Hello, The 30 amp MTTP controller on my 400 watt system sez that is over charging the batteries some times,, that can't be good...
What is the most likely issue, please??? Just learning,,,,
    Re: MTTP controller sez "overcharge" (some times )
    What controller is it exactly?
    Also, are there any other charging sources connected?
    BB. Super Moderators, Administrators Posts: 33,728 admin
    Do you have a volt meter (that you trust) so you can measure the voltage at the battery / battery bank (and individual cells/batteries)?
  • uncledave
    I guess that is my next purchase,,,,
  • inetdog
    uncledave wrote: »
    While you are at it, if you have around $50 to spare, get a Sears multimeter with DC clamp-on ammeter function. That is a real life saver for PV.
    SMA SB 3000, old BP panels.
