Update on off grid cabin equipment.. Any ideas on a inverter that wont break the bank.
squzzie
Registered Users Posts: 9 ✭
2 hightech solar 435w72 volt panels
proper roof mounting hardware
outback flexmax 60
and all proper mc4 connecters and cable
4 deep cycle
6 volt
110 minutes/75amps
roof mount wind generator dycore wind generator roof mount 400w and 10-15 mph 2.2kw at 20-25mph
Any suggestions on change of equipment or configuration.
Thank you,
outback flexmax 60
4 deep cycle
6 volt
110 minutes/75amps
Thank you,
Re: Update on off grid cabin equipment.. Any ideas on a inverter that wont break the ban
Don't mount a wind turbine in an inhabited structure if you hope to sleep in it...
What is the system voltage?
what Charge controller?
Panels in parallel?
what equipment do you want to run with the inverter?
What are your loads (in detail) ? There's not point getting all of that equipment if you don't know what you need to run.
I suspect that those are not deep cycle batteries. You may want to rethink them, AFTER you figure out your loads.
- 230 Forum & Website
