Saving my unsuitable batteries, help please!
CALLDCALLD Solar Expert Posts: 230 ✭✭
As a first time off-gridder still learning so much about batteries it's finally dawned on me that I need to change
my approach to this urgently to avoid getting sucked into a bottomless pit of expensive battery replacement cycles!
My problems are the following:
1) That I decided to go with PV in the first place not knowing it would cost far more to maintain than the power
savings would ever offset!
2) Grid-tie is not an option here as our utility doesn't offer credits or buy-back for any extra power generated.
3) Our power grid is proving to be a lot more reliable than I anticipated when I first decided I needed batteries to save me from bumping my head in the dark. There were horror stories in the news of the national grid collapsing and it taking 2 weeks to recover, but so far we have not had one power outage of even 5 minutes since all the doom mongering started 6 months ago. Very annoying!!!
What am I to do? I don't have true deep cycle batteries so I cannot carry on as usual using an off-grid system just
to make use of my solar panels when the cost of replacing these batteries is going to far outstrip any savings
made by generated power. Even if I wait and see how long they keep going before replacing them with industrial
grade deep cycle cells - the type that can go down to 80% DOD >1000 times, the economics still don't make sense.
I have a simple idea where I could win on both fronts while still keeping my current setup, but I need the brainy
boffins on here to critique it and tell me if it's worth a shot!
My batteries are probably half-way through their useful lives now, having clocked up about 100 cycles to
approximately 50% DOD, their warranties covering 250 such cycles.
My idea: The charge controller takes them up to a certain user pre-set voltage, then starts pulsing the power from
the PV to keep it from rising further. This creates a voltage difference between the + pole on the PV input and
the + pole on the battery output of the controller. This difference can be anything up to 10 volts, enough to
light up a small bulb for instance. This bulb can trigger a Day/Night sensor, the kind that can be cheaply
purchased at any DIY store. This Day/Night sensor could be used to trigger a timer that sends power from my
2500watt inverter to my hot water cylinder for lets say 5minutes and then switches off. This would discharge the
batteries by no more than 3%. The batteries would then charge using any available PV power until the voltage
reaches the set point, PV exceeds battery, bulb lights up, timer starts. Process repeats until PV production drops
off and can no-longer light the bulb. The point is to maintain the batteries in the top 10% of their SOC.
Brain Boffins - will it work???
If so, can it be done better than I explained???
Obviously in the event of a power cut I could manually switch off the how water cylinder and use the batteries for
back-up, but this is only likely to happen once in a blue moon with things as they are.
  • CariboocootCariboocoot Banned Posts: 17,615 ✭✭
    Re: Saving my unsuitable batteries, help please!
    Sell the stuff and try to recoup some of your money.
  • Mountain DonMountain Don Solar Expert Posts: 494 ✭✭✭
    My thoughts too. If you still feel you want backup power go for a generator. If you have propane appliances there are generators that run on propane. Engines run cleaner on propane and there is no hassle, dangers, or old fuel degradation issues as there are with gasoline.
  • vtmapsvtmaps Solar Expert Posts: 3,738 ✭✭✭✭
    CALLD wrote: »
    I cannot carry on as usual using an off-grid system just to make use of my solar panels when the cost of replacing these batteries is going to far outstrip any savings made by generated power.
    You seem to understand the issue. Sell the equipment. --vtMaps
  • CALLDCALLD Solar Expert Posts: 230 ✭✭
    Wow so selling my equipment is the only sane option? It's a bitter pill to swallow but I can't argue with the experts. It's gonna be hard finding buyers for used batteries though, no sane person who knows anything about batteries will buy them for anything that resembles decent money. Think in this instance I may have to just bite the bullet and try to get the most out of my system. Being a white man in Africa one learns to make do with what you have, unfortunately those rules aren't going to change anytime soon. Will try out my idea, will keep thinking of ways to make it cheaper and more robust and reliable before setting it up. Contemplating a small resister to generate some heat from the excess voltage, which in turn activates a thermostat/relay instead of using a timer. For those who may want to offer me some useful advice, my main aim here is to use as much of the power during the day as possible. Unfortunately I cant dump the power from the panels directly into the hot water cylinder as there is no such thing as an element that heats up optimally under all levels of PV production...
  • Blackcherry04Blackcherry04 Solar Expert Posts: 2,490 ✭✭✭
    Put a active High voltage switch, anytime the batteries get above the set voltage level the switch will trigger a transfer on a SSR / Relay.
    http://www.solar-electric.com/catalogsearch/result/?q=voltage+switch&cat=0
