Capacity testing
CALLD
Solar Expert Posts: 230 ✭✭
I'm keen of giving my 24v 400AH battery bank a capacity test, but want to avoid running them down to the inverter's 20.8v LVD unnecessarily. Is this possible? They aren't proper deep cycle batteries so I don't want to punish them anymore than being in a RE application already is. Is it possible to use data gathered from a half-hour run at a C/3 load? It's the most brutal test I can think of. It would involve me hooking up a 2000w electric heater and a few other appliances to bring the total load to 2500w, which is the maximum rated power of my inverter. If I take voltage readings every 5mins and plot a graph could I tell anything from the discharge curve? Maybe like trying to project where the final cut-off point will occur? Obviously would have to take Peukert's law into account.
Has anyone done this?
Re: Capacity testingI'm keen of giving my 24v 400AH battery bank a capacity test, but want to avoid running them down to the inverter's 20.8v LVD unnecessarily. Is this possible? They aren't proper deep cycle batteries so I don't want to punish them anymore than being in a RE application already is. Is it possible to use data gathered from a half-hour run at a C/3 load? It's the most brutal test I can think of. It would involve me hooking up a 2000w electric heater and a few other appliances to bring the total load to 2500w, which is the maximum rated power of my inverter. If I take voltage readings every 5mins and plot a graph could I tell anything from the discharge curve? Maybe like trying to project where the final cut-off point will occur? Obviously would have to take Peukert's law into account.
If they are NOT deep cycle batteries, you definitely need to be careful.
This is for Surrettes Deep cycle.
Attachment not found. -
Thank you @Blackcherry04. I am concerned that these hybrid type batteries may have lost some of their capacity because the voltage under load seems to drop much faster than I expect. I'm getting down to 24.0v after removing just 50AH from them after they've been charged to the point where they will no longer accept any meaningful current. That's a 400AH battery with a +/- 15Amp load on it for 3 hours and 20mins. I cannot verify their SOC with a hydrometer because they are sealed, but they do have those little green magic eyes which are showing "fully charged" so that's the closest thing I have to a SG reading. The furthest I've pushed them is by discharging 3.6kw/h as shown on a kill-a-watt meter from them over 16 hours with no incoming charge. The voltage under very light load was 23.2v. I then applied a heavy load of 2300watts on the inverter which dragged the voltage down to 22.2volts after 5mins. The SOC at the point should have been around 50%. Seems a bit low when looking at the discharge curves for deep cycle batteries. Unfortunately as is the case with many cheap and nasty products, information from the manufacture is non-existent. I can't even get charging instructions for these batteries nevermind discharge curves... -
Re: Capacity testingI cannot verify their SOC with a hydrometer because they are sealed, but they do have those little green magic eyes which are showing "fully charged" so that's the closest thing I have to a SG reading.
Chances are that you do not have truly sealed batteries (not freely vented, able to be mounted in any orientation). You probably have "maintenance free" batteries which are basically normal FLA batteries that have extra headroom above the plates for more electrolyte and cell vent caps that are very hard to open.
You can probably pry them open carefully to check SG, but it is not clear whether that would really tell you anything.
They may have high internal resistance as well as some loss of capacity.SMA SB 3000, old BP panels. -
Re: Capacity testingI then applied a heavy load of 2300watts on the inverter which dragged the voltage down to 22.2volts after 5mins. The SOC at the point should have been around 50%.
Post a picture of your Battery setup and let us see it. What size cables do you have ?? -
Thank you Blackcherry04 and inetdog, your info is definitely helping me to form an opinion on what may be the problem. I've long suspected that the internal resistance may be very high in these batteries, but it may also be down to how I've set things up since the very beginning. The battery bank has sort of evolved along with my learning curve. It has also grown. I started out with half the amount of capacity in the beginning but quickly added more as I realized that DOD was such an important issue especially with these batteries. I've pretty much taken nearly every rule with regards to mixing new and old batteries, wiring in parallel strings and charging parameters and "bent them". These batteries have really been my training wheels. Just trying to determine how long they can still keep on going before some sort of cascading failure occurs.
If it's of any use these are the batteries in question:
http://www.battery.co.za/wp-content/themes/battery/dl/Excis%20April%202012.pdf
This is pretty much all the manufacture gives...
- 220 Forum & Website
- 128 Solar Forum News and Announcements
- 886 Solar Product Reviews & Opinions
- 651 Solar Water Pumping
- 606 Discussion Forums/Café
- 300 In the Weeds--Member's Choice
