Solar energy that doesn't block the view
RSSfeed
Registered Users Posts: 3,810 ✭✭
Researchers have developed a new type of solar concentrator that when placed over a window creates solar energy while allowing people to actually see through the window. It is called a transparent luminescent solar concentrator and can be used on buildings, cell phones and any other device that has a flat, clear surface.
More...
More...
Re: Solar energy that doesn't block the view
Well, I guess if the space is not usable for anything else, like a traditional panel, then 1-5% efficiency is still better than nothing. Oh wait, you have to buy the things and install them too....Lunt said more work is needed in order to improve its energy-producing efficiency. Currently it is able to produce a solar conversion efficiency close to 1 percent, but noted they aim to reach efficiencies beyond 5 percent when fully optimized. The best colored LSC has an efficiency of around 7 percent.SMA SB 3000, old BP panels.
- 230 Forum & Website
