Question About AC Model # on 95' Lance Squire?
Lexicon7
Solar Expert Posts: 50 ✭✭✭✭
Hi Guys, I know this isn't a Solar question but it is about energy use. I need to know the draw on my Dometic Penquin Duotherm AC and neither Lance or Dometic were any use. I went up and removed the shroud but only found Model #'s on the heat pump tank and the motor & nothing on the actual unit..
I gather is is either 11,000 or 13,500? Anyone have any ideas or a site that may assist...?
Re: Question About AC Model # on 95' Lance Squire?
Clamp-on Ammeter, run unit, measure current? -
Other than that? -
OK so 115V
Ouch Lock Rotor Amps 50-64,
hope your not planning on running this off a small setup! Or even off a small grid line.
http://www.dometic.com/enus/Americas/USA/RV-Products/climate/ac-display-page/?productdataid=66930
Here is an installation manual for some of the 13500 BTU models, those contain a 12amp compressor.
http://www.dometic.com/FileOrganizer/1-international/Operation%20&%20Installation%20Manuals/Air%20Conditioners%20-%20Vehicles/Penguin%20AC%20Install.pdf
Page 3 has specs sheet. -
Why not? I'll just run it with my Wallmart Everstart 94 and my 55W charger....!
- 621 Discussion Forums/Café
