Looking for unistrut solar panel end-clamps...
MaineCabin
Solar Expert Posts: 29 ✭
Hi,
I just installed a couple of new solar panels using unistrut. I tried to jerry-rig some end-clamps but they are not working so well. Does anyone know where I can buy some purpose built end-clamps that work with unistrut? Or share a good design? (Supposedly unistrut makes a clamp but I cannot find where to buy them)
My panels are 1.5" deep.
Thanks!
Thanks!
Re: Looking for unistrut solar panel end-clamps...
M C,
Guess that you have seen this:
http://www.eberliron.com/public/files/literature/unistrut/Unistrut_Solar.pdf
I might try using a Strut Channel Nut, and someone else's Clamp.
The UniStrut, B-Line, etc PV mount products may be special-order from your favorite local wholesale Electrical Distributor, but often from semi-local warehouse stock.
FWIW, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
and there is the S-5 product http://www.s-5.com/solar/index_2559.cfm#1
the pic shows the unit with a clap for standing seam metal roof, that part is not needed
Thanks for the tips!
- 226 Forum & Website
- 617 Discussion Forums/Café
