GVFX sell settings recommendations
verdigo
Solar Expert Posts: 428 ✭✭
Still waiting on my inspector and the utility guy to come give me their blessings, so I decided to run a 15 amp cord to my inverter's AC IN. So far I have just set the charger settings a couple of volts below the classic to make it sell. Then I just turned off the inverter's charger, and it is supplementing the house.
I am hoping to get some recommendations for settings and whether or not to use the HBX mode and there is a setting for "aac" that is a little vague to me. Any discussion would be appreiciated. The battery bank is full and it seems to be digging into them a little at the time but the sun is not optimum either. Its early.
And no I do not plan to walk away from the system today operating on an extension cord. Just trying to get a feel for things right now.
Question: What limits how much current the inverter can sell? I have seen up to 1.2 KW, and then it drops to .8 KW. The classic has reached float voltage, and the amps are dropping off. I increased the float voltage and no change on the inverter output. The inverter as measured with a multi-meter says 129.5 volts AC. So my guess is that the higher the grid voltage is then this is limiting inverter output?
Dennis
Dennis
Re: GVFX sell settings recommendationsStill waiting on my inspector and the utility guy to come give me their blessings, so I decided to run a 15 amp cord to my inverter's AC IN. So far I have just set the charger settings a couple of volts below the classic to make it sell. Then I just turned off the inverter's charger, and it is supplementing the house.
Dennis
The only place you can limit amps AC is the ACin and The charger amps. -
Oh well. I'll get it figured out. I am having fun though. -
No more fun today. The smoke has come out of the inverter. -
Re: GVFX sell settings recommendationsNo more fun today. The smoke has come out of the inverter.
Please tell me you're kidding.
It is extremely difficult to burn up an Outback. You have to do things quite horribly wrong. -
Re: GVFX sell settings recommendationsCariboocoot wrote: »You have to do things quite horribly wrong.
Not kidding. I'm just sick to my stomach. My design worked but was too complicated. If the breakers were all in their correct positions, and operated in the right order their wouldn't have been any problem. (famous last words). In another thread I ask what would happen if the AC out backfed the inverter's own AC In. Well I think what happens is the transfer switch goes nuts. Makes a real scary clattering noise. Then the idiot standing there (yours truly), panics, and starts grabbing for breakers and grid meets inverter output and inverter loses.
Long story short. If it can go wrong it will. I just hope it can be repaired.
Stupid Stupid Stupid!!! -
Sounds like the AC board ( Some call it the FET board ) with the transfer relays chattering, unfortunately it's the most expensive. -
Is this something I can field replace? Any idea how much the board costs, or should I be thinking about replacing the inverter? -
Re: GVFX sell settings recommendationsIs this something I can field replace? Any idea how much the board costs, or should I be thinking about replacing the inverter?
Contact Outback; they're best able to tell you what it would cost and how easy/difficult it is to change (depending on your skill level). It is not going to be cheap as the AC board has the expensive power FETs on it. Best-case: the relay fried and can be replaced on its own. -
Board replacement
http://www.outbackpower.com/downloads/documents/m_series/m_series_fx_circuitboard_replacement.pdf -
Re: GVFX sell settings recommendationsBlackcherry04 wrote: »Don't know the cost, not hard to replace.
Board replacement
Do you know if the Inverter place in Whitehouse keeps any inventory on hand? -
Re: GVFX sell settings recommendationsDo you know if the Inverter place in Whitehouse keeps any inventory on hand?
Board replacement
There is youtube video too about Board replacement by Outback. -
Re: GVFX sell settings recommendationsThere is youtube video too about Board replacement by Outback.
Thanks. I checked that out. Looks like a piece of cake. -
The FET board is $240.00. The other two are $120.00 each. Not nearly as bad as I had imagined. -
Not exactly cheap, but cheaper than I would have thought. Good Luck on it. It's a lot cheaper than any of the Xanterx boards I have bought. -
I was thinking a lot worse. They even said that my warranty was still good whether I sent them the inverter or they sent me the board(s). Great company. This will play majorly on any future purchases I make, or any recommendations for equipment to others, and I am starting to get a lot of interest in my neck of the woods with door knockers and what not wanting to take a look, and you know Cave City hasn't exactly been the solar mecca of Kentucky up to this point. -
I got my new FET board yesterday, or so I thought. The board is clearly used and even dirty. Outback does want the core back, and I have no problem there, but I thought I was buying a new part. My inverter isn't even six months old yet. I didn't even notice it until I got it mounted. I know I am to blame for frying the board but I paid for a new one or so I thought, and its not like this is a warranty issue. I bought the board.
Hate to be a whiner, but I am never gonna feel right about the longevity of the inverter now. Feel like I should at least got a kiss. -
Re: GVFX sell settings recommendationsI got my new FET board yesterday, or so I thought. The board is clearly used and even dirty. Outback does want the core back, and I have no problem there, but I thought I was buying a new part. My inverter isn't even six months old yet. I didn't even notice it until I got it mounted. I know I am to blame for frying the board but I paid for a new one or so I thought, and its not like this is a warranty issue. I bought the board.
I'll suggest you complain to them. Right away. Before you install the board. As in you take the 'new' board out of the box, look at it and say "this isn't a new board" and tell them all about it. If you accept it and install it that means you're satisfied with what they sent.
I don't know how you can tell it is used (clipped wires hanging off it?) but it may be one that's sat around a while in storage. I still wouldn't settle for it if there are any doubts. -
Sometimes people have been known to slip old/used/broken hardware into boxes--Outback may not even know that they shipped you a "used" board.
Is there any serial number (or part number/revision) tracking information in the documentation/on the outside of the box (that agrees or disagrees with what is marked on the board)?
I'll have to check. I left the shipping/invoicing documents in my office which is too far to drive until Monday. The electrostatic bag had a new seal on it though. -
Re: GVFX sell settings recommendationsThey even said that my warranty was still good whether I sent them the inverter or they sent me the board(s). Great company.I got my new FET board yesterday, or so I thought. The board is clearly used and even dirty. Outback does want the core back, and I have no problem there, but I thought I was buying a new part.
Wait a minute... which is it? Are they replacing the board under warranty? or are you buying a new board?
It it's under warranty, you can expect a refurbished board, and you should be very grateful that you did not have to pay for your the damage you caused. If you are, in fact, paying for a new board, then you should complain about getting a used board.
I bought the board. I wouldn't dream of trying to warranty out on something I did. Even if its refurbished it doesn't appear to have even been cleaned. So far the AC out on batteries is working though. Gonna try the grid interactive functions next. -
Re: GVFX sell settings recommendationsI bought the board. I wouldn't dream of trying to warranty out on something I did. Even if its refurbished it doesn't appear to have even been cleaned. So far the AC out on batteries is working though. Gonna try the grid interactive functions next.
I'd say, call them and talk about it. As a manufacturer myself, I'd much rather have a customer be up front than hear a snow job. If your fat Girlfriend sat on it and broke it, say so, and I'll send you a new one Free and pay the postage, most Manufacturers like customer feed back, good or bad. -
Thats my intention. I'm gonna box up the core Monday and give them a call. The replacement board works. I went ahead and installed it to make sure the other two boards were okay, and the inverter works in off grid and it's interactive mode. The part they sent me didn't look like it had any work done to it. It has a thin layer of dust on it I guess that is normal for a vented inverter. I just don't like the idea that it may have lived half of it's useful life already. Bottom line is I want a new one. I'll pay the difference if there is one. -
Just an FYI for anyone interested. According to the tech support guy I just spoke to at Outback, new boards must be purchased through an authorized Outback Dealer. All boards directly from Outback are refurbished. The same fellow I spoke to at Outback told me a new FET board is $600.00 (Probably MSRP). I just spoke to Dan at NAWS, and he priced me one for $435.00.
I just have to decide if I want to keep the refurbished board or not because stupidity unlike lightning does strike more than once in the same place -
Getting back to sell settings I have found (after I took my batteries into a bad place for a while), that if I set the inverter to do an absorb for 30 min each morning to bring up the night's tare losses that it is best to set the Classic a couple of volts above float and the GVFX at float. Then the inverter sells all day everything above the set float voltage. -
Blackcherry
are you saying outback sells refurbised board for $240? I just payed $480 and I would have went with refurbished. This was less then a month ago. I did get all three boards and had to send them mine back or it would have been $800 something.
gww -
I paid $240 for a refurbished fet board from outback. Outback said it would not affect warranty. -
gww
- 228 Forum & Website
- 653 Solar Water Pumping
- 618 Discussion Forums/Café
