Momentary Output spike to 0.0kwh
newmex999
newmex999 Registered Users Posts: 7
Noticed that there was a momentary spike downward today in my output from 5kwh to 0.0kwh, then right back up again. Not a cloud in the sky
If there is a momentary blip in the power coming from the grid, can it cause this? The blip, if it occurred(I wasn't home) was not long enough so that I had to reset clocks/etc.
System is 7 months old and this is the first time I have noticed something like this.
    Re: Momentary Output spike to 0.0kwh
    What brand/model of system do you have?
    Grid tied, hybrid, or what?
  • newmex999
    Sunpower panels, 6000 Inverter, grid tied.
  • inetdog
    Question to think about:
    Is this really a dip in the GTI output or is it a glitch in the output reporting via network, etc.?
    It may be that all you are seeing is a problem with the GTI reporting output or the monitoring programs data communications.
    If the inverter drops out because of an apparent grid problem, I would expect 5 minutes or more to go by before the inverter re-qualified the AC input and started up again.
    SMA SB 3000, old BP panels.
  • solar_dave
    If the utility line is "unstable" it can cause the grid tie inverter to reset and re-qualify the line. Were the outages about 5 minutes in duration, usually that is the 300 sec required for the reset.
    All it takes is the utility to mess with either the voltage or line frequency to get it to happen. I see it here occasionally and suspect cutting in/out transmission can cause it.
  • newmex999
    solar_dave wrote: »
    Dip occurred at 1:55pm and inverter was back online at 2:05pm, so it appears it may have been the utility company doing something. Thanks
