Controller for odd panel
lipets
Solar Expert Posts: 61 ✭✭
I have two Kerocyra panels 195W. hip-195-ba19
I want to use both of them on an RV with 4 6V batteries a 12 volt battery bank.
I was looking at the TriStar MPPT Model TS-MPPT-30
the specs on the panels are
Voc 68.1
Vmp 55.3
Lsc 3.8 A
your suggestions
Voc 68.1
Vmp 55.3
Lsc 3.8 A
your suggestions
Re: Controller for odd panel
That is a good combination... You can also look at the:
Rogue 30 amp MPPT
Midnite Kid 30 amp MPPT
Both of those are very good MPPT charge controllers too. boB from Midnite posts here very often, and they have their own forum. Marc from Rogue also has posted here (in the past) pretty often too. Both have very good after sale support reputations.
