materials price information
slick.solar
Registered Users Posts: 3
Hi there!
I need price information for the following materials, these are necessary for the concentrated solar thermal power generation project that I need to start. Here they are:
PBS pigment with silicon binder
copper-chromium oxide pigment,ethylene-propylene diene monomer binder
acrylic (plexiglass)
Kinglux
UCON 500 (union carbide)
Caloria HT 43 (Exxon)
3M scotchcal 5400
3M FEK-163
Alzak
Kinglux
3M scotchcal 5400
3M FEK-163
Alzak
Re: materials price information
Heres some more information on these materials:
selective paints
absorptance emittance Temp (`C)
1) PBS pigment with silicon binder 0.90 0.37 350
2) copper-chromium oxide pigment,
ethylene-propylene diene monomer 0.92 0.30 not known
binder
cover
index of refraction = 1.49
shortwave transmittance = 0.90
longwave transmittance = 0.02
Density = 1189 kg/m3
Thickness = 3.175 mm
Max Temp = 93 `C
Cost = $9/m2
3) Reflective sheet
metallized plastic films
i) 3M scotchcal 5400
Relative weight R1 = 0.86
Hemispherical reflectivity Rs(2pi) = 0.85
ii) 3M FEK-163
Hemispherical reflectivity Rs(2pi) = 0.86
iii) Alzak
Relative weight R1 = 0.66
Only 0.66 of the light incident on kinglux is reflected even
though hemispherical reflectance is 0.85
4) Kinglux
Relative Weight R1 = 0.65
Hemispherical refectivity Rs(2pi) = 0.85
Only 0.65 (ie 65%) of the light incident on the kinglux is
reflected to the absorber even though hemispherical reflectance is 0.85
Cost = $8 - $35/m2
5) HTF (Heat Transfer Fluid)
Polyglycol
i) UCON 500 (union carbide)
Freezing point = -37 `C
Boiling Point = 289 `C (max temp)
Thermal conductivity = 0.15 W/mk
Specific Heat = 2.2 kJ/kg.K (at 100 `C)
ii) Paraffinic hydrocarbon
Freezing point = -9.5 `C
Boiling Point = 311 `C
Thermal Conductivity = 0.13 W/mK
Specific Heat = 2.1 kJ/kg.K (at 100 `C) -
Any help on finding out the prices of these materials would be greatly appreciated.
Thanks! -
Your questions are not those we deal with much on this forum...
And I assume you would like the materials to be delivered/available in Pakistan?
