Roof rack angle?
Arkansasoffgrid
Solar Expert Posts: 117 ✭✭
With a fixed position roof mounted array, what is the optimal angle with a latitude of 34.3779, longitude -93.2405 ? This is a south facing roof, with absolutely no shading.
8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator.
Re: Roof rack angle?
What is your load profile?
If you use AC during the summer and not too much power during winter, then flattening the array to ~(34 degrees - 15 degress=) ~20 degrees from horizontal.
In theory, ~34 degrees from horizontal will collect the most energy over a 1-year period.
Use PV Watts and "play" with the numbers to see what is best for your location/needs (PV Watts takes "average" weather into account). You can also play with facing array South East vs South vs South West--Morning fog vs afternoon thunderstorms, Cooler mornings (Vmp is higher, more power) vs afternoon A/C (use afternoon power to run AC instead of batteries)... Using 0.52 system eff for off grid vs 0.77 default:"Station Identification"
"City:","Little_Rock"
"State:","Arkansas"
"Lat (deg N):", 34.73
"Long (deg W):", 92.23
"Elev (m): ", 81
"PV System Specifications"
"DC Rating:"," 4.0 kW"
"DC to AC Derate Factor:"," 0.520"
"AC Rating:"," 2.1 kW"
"Array Type: Fixed Tilt"
"Array Tilt:"," 34.8"
"Array Azimuth:","180.0"
"Energy Specifications"
"Cost of Electricity:"," 7.4 cents/kWh"
"Results"
1, 3.78, 237, 17.54
2, 4.38, 244, 18.06
3, 5.19, 312, 23.09
4, 5.67, 318, 23.53
5, 5.89, 331, 24.49
6, 5.81, 309, 22.87
7, 5.93, 320, 23.68
8, 6.08, 332, 24.57
9, 5.41, 291, 21.53
10, 5.16, 299, 22.13
11, 3.69, 213, 15.76
12, 3.56, 218, 16.13
"Year", 5.05, 3422, 253.23"Station Identification"
"State:","Arkansas"
"Elev (m): ", 81
"Array Tilt:"," 20.0"
"Results"
1, 3.33, 207, 15.32
2, 4.04, 224, 16.58
3, 5.04, 303, 22.42
4, 5.80, 326, 24.12
5, 6.26, 355, 26.27
6, 6.31, 338, 25.01
7, 6.36, 346, 25.60
8, 6.29, 344, 25.46
9, 5.34, 287, 21.24
10, 4.81, 278, 20.57
11, 3.32, 189, 13.99
12, 3.10, 186, 13.76
"Year", 5.01, 3383, 250.34"Station Identification"
"State:","Arkansas"
"Elev (m): ", 81
"Array Tilt:"," 50.0"
"Results"
1, 4.02, 253, 18.72
2, 4.48, 250, 18.50
3, 5.06, 303, 22.42
4, 5.23, 292, 21.61
5, 5.20, 291, 21.53
6, 5.01, 263, 19.46
7, 5.18, 275, 20.35
8, 5.54, 300, 22.20
9, 5.19, 278, 20.57
10, 5.23, 303, 22.42
11, 3.87, 224, 16.58
12, 3.82, 236, 17.46
"Year", 4.82, 3268, 241.83
Don't get too wrapped up in the calculations--Real life will interfere and limit your accuracy to around 10% (year to year average variations). If you think you will need more power (don't plan on using 100% of predicted power daily, perhaps ~66% to 75% daily power, plus optional wash day/more A/C when plenty of sun, cut back in bad weather, run genset).
You can generate lots of data doing this. But it will give you a good feeling about how much you can affect your harvest with changes to your array installation.
Using the above link, at location of Hot Springs Arkansas my summer panel angle should be 10.62°, and winter angle should be 49°. Does that sound about right?8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator. -
One question, which time of the year will you need the most power, Summer , Winter or Fall/Spring? that determines your optimal angle... in my case it is winter, Summer I have no worries of meeting needs...
Definitely summer, trying to keep house cool. Winter we'll have wood heater.8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator. -
Arkansasoffgrid says your a not so new guy. can I ask you a question? -
Sure, but that status must have gotten changed due to the amount of questions I've asked, not the amount of experience I have.8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator. -
Re: Roof rack angle?Arkansasoffgrid wrote: »Sure, but that status must have gotten changed due to the amount of questions I've asked, not the amount of experience I have.
Yes, that's how it works; more posts automatically move you up the ladder. :roll: -
I would set mine to noob if I could until I don't have to ask as many questions. I may not live that long though.
