Which switches and fuses to use in solar panel / battery / load setup
louisbanens
Registered Users Posts: 16 ✭
I am wondering which switches (to disconnect) and fuses to use in my solar panel / battery setup.
I have got a 170w Solar Frontier panel (87V nominal, 2A nominal current) and a 75ah optima battery. My usage is no more than 25A current (300watt): 15watt ledlights and 60watt laptop and sometimes a 300watt pure sinus inverter
I would say:
- A switch and fuse between solar panel and charge controller: which one?
- A switch and fuse between battery and charge controller: which one?
- A switch and fuse between battery and load: which one? (something like this?: http://accuweb.nl/accu-toebehoren/massa-schakelaars/massa-schakelaar-12-24-volt-100-a/).
I would say:
Re: Which switches and fuses to use in solar panel / battery / load setup
Hi Louis,
Generally a DC-rated Circuit Breaker does the job well. The following are DIN-Rail mount breakers:
http://www.solar-electric.com/mnepv.html
These Panel Mounts are also nice:
http://www.solar-electric.com/pamodccibr.html
Boxes for the above breakers;
Din rail with enough room for 4 or so breakers:
http://www.solar-electric.com/misobigbabox.html
A very small Din rail box for two or perhaps three breakers, but it can be very tight, especially with larger cables:
http://www.solar-electric.com/baby-box.html
Panel mount box:
http://www.solar-electric.com/mnedc-quad.html
The above products are what are in use here, they work great, and the breakers and boxes are usually Code compliant and are inexpensive.
Have Fun, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum.
