Direct drive washing machine, power consumption
zoneblue
Solar Expert Posts: 1,220 ✭✭✭✭
As promised here is a 1 second Whizbang plot for a clothes wash cycle using a F&P smartdrive washer.
Here i turned off all loads except a stable 2A background baseload, and the also turned off PV (as the charge controller sometimes introduces some noise on the WBJr data stream) for the duration.
Points to note:
- cold wash on 3/4 full setting
- this is DC power usage, hence the data incorporates inverter losses.
- the data also incorperates the water pump that runs continously whenever the washer draws water. Its a flojet 24v model, and you can see it running alone just at the start of the curve. I wont attempt to calculate what proportion of the total draw was from it.
- cycle time was 54 mins.
- total cycle use was 139.8Wh.
- average draw was 154W.
- peak draw (early in final spin) was 419W.
- idle tare is 5W.
Points to note:
- idle tare is 5W.
Re: Direct drive washing machine, power consumption
Hi . Interesting . What model was that . they have an "eco model ". Not sure what the eco model incorporates .2225 wattts pv . Outback 2kw fxr pure sine inverter . fm80 charge controller . Mate 3. victron battery monitor . 24 volts in 2 volt Shoto lead carbon extreme batterys. off grid holiday home -
I will try to log the same data with my new direct drive washer in 1 second intervals. Remember, mine is a standard "energy efficient" top-load Maytag Centennial model but has no clutch or transmission and just reverses the motor every second to agitate.
But since I have a bunch of other stuff running at the same time, I would have to figure out a way to eliminate all of it (other than turning those things off - which I might just have to do for the washer cycle).Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html -
Re: Direct drive washing machine, power consumptionpetertearai wrote: »Hi . Interesting . What model was that . they have an "eco model ". Not sure what the eco model incorporates .
Its an older model, GW601. The F&P smart drive line were first manufactured in 1991. Not much has changed internally since that original design. Theres a service manual for much of the range here: http://www.angelsnz.net/ZL3SV/misc/F&P%20Service%20manual%20517735.pdf
Yes, suprisingly difficult to depower ones house. Still, its only the eratic loads you need off, stable ones you can just leave as a baseline.1.8kWp CSUN, 10kWh AGM, Midnite Classic 150, Outback VFX3024E,
I bought my samsung 4.2 model last week wich is also a direct drive. I am not sure the exact measurements on mine but I imagine they are far superior beings that the annual usage energystar estimation is at 7 dollars when using gas water heater or only using cold water. I am super happy with my unit.
Thanks a bunch zone blue for taking your time to do this test. I wanted to be well informed before jumping in to an expensive purchase. I kinda went with my gut on this one. Obviously its a bit hard to test an item when its still on the shelf. Sometimes its a crap shoot but I think I got lucky as mine works well with little battery consumption.
- 228 Forum & Website
- 618 Discussion Forums/Café
