Measuring Ceiling Fan Power Usage
Rkg76
Rkg76 Solar Expert Posts: 35 ✭✭
This may be a dumb question, but how would I go about measuring the power usage on a hardwired ceiling fan...measure it somehow at the electrical panel? My assumption is a Kil-a-watt meter is useless for this as there is nothing to plug-in?
Russ
    Re: Measuring Ceiling Fan Power Usage
    Rkg76 wrote: »
    Russ
    You are correct: the K-A-W is useless unless you can get at the wiring to (just) the fan and put a plug and socket in. Otherwise if you know precisely what circuit it is on and can access the wiring for it you can use a clamp-on AC Ammeter to measure the power draw. That "access the wiring" is the difficult bit; often the only place you can get to it is inside the main panel box and that will be full of live wires when you run the test.
    Plus to "properly" measure power usage, you need access to both the circuit voltage and current (some sort of current tap/current transformer) to measure both the amplitude and the "phase" of the voltage and current...
    Otherwise you can only measure the current and estimate:
    VA = Voltage * Current (AC power measurements--As separate readings).
    To actually measure power:
    Power = Voltage * Current * cos (phase angle) = Voltage * Current * Power Factor (one meter, same time, volt+amp measurements).
    That is what the KaW meter does--It measure both at the same time.
    Somebody here made up an "outlet" where they could wire the KaW meter into their AC panel Branch Circuits--Can be done, but you have to know what you are doing or you could cause some real havoc.
