What was the initializing procedure for new deep cycle batteries?
unyalli
Solar Expert Posts: 121 ✭✭
Ok I've been searching and can't find the battery initializing (or was it qualifying) procedure for new flooded lead acid batteries. Can I get a pointer?
Jeff
Jeff
Re: What was the initializing procedure for new deep cycle batteries?
You mean "commission charging" perhaps? That's the process of charging brand new batteries according to manufacturer's specs so that every cell is at full and equal SG. -
Re: What was the initializing procedure for new deep cycle batteries?Cariboocoot wrote: »You mean "commission charging" perhaps? That's the process of charging brand new batteries according to manufacturer's specs so that every cell is at full and equal SG.
There you go! Commissioning. Off to the search bar. Thanks
Jeff -
Well I'm still not finding it. I know I found a document on initializing or commissioning a new battery bank. Where is it? Pretty sure it was at windsun.
Jeff -
Re: What was the initializing procedure for new deep cycle batteries?Well I'm still not finding it. I know I found a document on initializing or commissioning a new battery bank. Where is it? Pretty sure it was at windsun.
Jeff
Might have disappeared in the recent server upgrade attempt.
Use Google for short terms: site:wind-sun.com commissioning charge
More or less you just charge the batteries until every cell reads full SG according to what the maker says that should be. -
Hi Jeff,
Some manufacturers of Flooded batteries, like Surrette Battery, recommend Commissioning a new FLA bank. This would be to measure and record terminal voltage of each battery, check electrolyte level and record level for any cell that was LOW, measure SG of each cell and record, top up any cell to just above the plates, if the electrolyte was very low. Then fully charge the bank, followed by the commissioning EQ.
Believe that the above would not be a bad thing to do. Having a battery log book is also a good thing to record periodic SG readings of each cell, EQ date and time, and date and amount of Distilled Water added to the bank, and any other details of note.
However, for an RV House Bank, this might be a bit over the top. YMMV, opinions, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
So the bottom line is do a full three stage charge then check fluid levels and ensure no plates are exposed then do a full equalize? -
Re: What was the initializing procedure for new deep cycle batteries?So the bottom line is do a full three stage charge then check fluid levels and ensure no plates are exposed then do a full equalize?
And after all that, if the SG of any cell is not up to where the manufacturer says it should be when fully charged, do an additional, or if needed, an extended EQ until all cells are up to the required SG and they all closely match in SG.
What do you have for batteries? Make and model? How many of these batteries do you have, and what is the system voltage? -
Those are good things to do, but you left out the MOST important: Check and record the specific gravity of each cell.
I would check the fluid level and voltage and production date code before I ever took the batteries home. Just a reminder: you cannot make sense of the SG if you have just watered the battery.... you will need to charge it at absorb voltage for awhile to stir the electrolyte.
Re: What was the initializing procedure for new deep cycle batteries?waynefromnscanada wrote: »And after all that, if the SG of any cell is not up to where the manufacturer says it should be when fully charged, do an additional, or if needed, an extended EQ until all cells are up to the required SG and they all closely match in SG.
Ok, the end of the story is blast them till there equal in all cells.
They are the Sams Club, Cosco GC2's. Look at the recommendation section over on the right.
Attachment not found. -
Re: What was the initializing procedure for new deep cycle batteries?Those are good things to do, but you left out the MOST important: Check and record the specific gravity of each cell.
Understood I have an SG device. -
AND, Jeff,
You should check the electrolyte level before charging. Only add water to cells that are very low. No need to add water before charging unless the plates are not fully covered. This exceedingly low electrolyte level is very, very unlikely, but good to check. Would return any new battery that have very low electrolyte level, anyway. Just good to know at the beginning.
Agree that buying batteries with the same Date Code, and good and nearly equal terminal voltages from measurements that you made prior to purchase is a great idea ... somehow, I had felt that these batteries were already purchased ... dunno. Good Luck, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
Re: What was the initializing procedure for new deep cycle batteries?AND, Jeff,
I have 2 GC2's right now that are around 3 years old that I did this initializing procedure on. I am going to trade them in for the core charge of $15 ea on a new set of 4 GC2's. I plan on treating the new set as a long term set and want the manufacture dates within a few months. I couldn't remember what this initializing procedure was. Old timers.
Jeff -
HALT!!!!!!!! STOP!!!!!!!! NOW!!!!!!
Checking the battery specs, it looks like these are sealed AGM batteries! If this be true, DO NOT try doing an EQ charge and DO NOT overcharge them, DO NOT "BLAST then with charge. You cannot check the SG on sealed AGM batteries and if overcharged, they will vent, dry out and be ruined!
Good thing you finally told us what you had for batteries. Hope it's not too late! -
Re: What was the initializing procedure for new deep cycle batteries?waynefromnscanada wrote: »HALT!!!!!!!! STOP!!!!!!!! NOW!!!!!!
No No No No No read further. These are 6 volt Golf Cart batteries. -
Re: What was the initializing procedure for new deep cycle batteries?No No No No No read further. These are 6 volt Golf Cart batteries.
Do these batteries each have 3 caps that can be easily removed so you can look into the battery and see the liquid level? -
Re: What was the initializing procedure for new deep cycle batteries?waynefromnscanada wrote: »Do these batteries each have 3 caps that can be easily removed so you can look into the battery and see the liquid level?
Yes, they have a 3 cap system where you rotate a lever and all three caps come off at the same time as an assembly.
- 611 Discussion Forums/Café
