23 Solar Power Funfacts
RSSfeed
Registered Users Posts: 3,810 ✭✭
1.*A solar panel is a set of photovoltaic modules, electrically connected assembly of solar cells. It is mounted on a supporting structure and can be used as a system to generate electricity in residential and commercial applications. 2.*Each module ranges for 100 to 320 watts, rated by DC output power under STC. The efficiency determines →The post 23 Solar Power Funfacts appeared first on Solar Feeds.
go to solarfeeds for the rest of this story>>>>>
More...
More...
Re: 23 Solar Power Funfacts
So poorly written I had to comment on how poorly written it is. -
Re: 23 Solar Power FunfactsCariboocoot wrote: »So poorly written I had to comment on how poorly written it is.
And just . . . wrong. Who wrote this? A journalism student?
"A photovoltaic system includes an array of solar modules or a panel, an inverter, a solar tracer or battery, interconnecting wiring."
"Micro inverters perform better than normal panels for they work independently."
"The conducting wires are connected to each other and to rest of the system, to achieve a desired output voltage." -
- 218 Forum & Website
- 185 Solar Information links & sources, event announcements
- 647 Solar Water Pumping
- 813 Wind Power Generation
- 599 Discussion Forums/Café
- 73 Construction
