"Solar package special"
Arkansasoffgrid
Solar Expert Posts: 117 ✭✭
http://www.wholesalesolar.com/solarpowersystems/large-home-2-off-grid-solar-power-system.html
This package is all inclusive, even roof racking. It's made in USA, and I'd really like your opinions on this "package price" of $10700.00 including shipping. The only thing not included is wire from combiner box to charge controller, and batteries.
8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator.
Re: "Solar package special"
Not this bunch again. *groan*
NO batteries = no system.
This is why off-grid systems are called "battery-based". You MUST design a system around the batteries. What you have there is a bunch of stuff they make a good profit on with no regard to whether or not it will meet the customer's needs. $2.58 per Watt, not including the essential batteries and installation.
Fifteen 265 Watt panels = 3975 Watt array. On a 48 Volt system that would provide 64 Amps charging power, enough for a theoretical 640 Amp hours of battery or 7.6kW hours DC @ 25% DOD (about 6.5kW hours AC or 8.2kW hours by the Icarus formula). Is that what you need?
This isn't the first time I've tried to steer people away from this marketing and these people specifically. It probably won't be the last. And NO, I DO NOT WORK FOR NAWS or anyone else. -
Read the small print racking is not included in the package. It is an optional item that will cost at least $1000. There are many other base of system components that you will need to source. Figure at least $15000 for the whole thing if you go with cheap batteries.
Ned -
Unfortunately these "special packages" are aimed to suck in those who aren't familiar with off grid solar systems. Such a shame they are doing this to innocent people. -
Re: "Solar package special"offgrid me wrote: »Read the small print racking is not included in the package. It is an optional item that will cost at least $1000. There are many other base of system components that you will need to source. Figure at least $15000 for the whole thing if you go with cheap batteries.
Ned
The roof mounted racking is a free promo. The advertisement is at top center of that page.8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator. -
Re: "Solar package special"waynefromnscanada wrote: »Unfortunately these "special packages" are aimed to suck in those who aren't familiar with off grid solar systems. Such a shame they are doing this to innocent people.8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator.
You're overlooking post #2 of this thread.
How much power do you need to supply?
That is the primary consideration for an off-grid system. Without that you're buying a bunch of "whatever" which inevitably leads to disappointment.
Then you size the batteries to fit those power demand needs.
This system may be too large or too small for what you require, and either way buying it is throwing away money. In other words you've got a 2/3 chance of it being wrong for you. Not good odds. -
Re: "Solar package special"Cariboocoot wrote: »You're overlooking post #2 of this thread.
This system may be too large or too small for what you require, and either way buying it is throwing away money. In other words you've got a 2/3 chance of it being wrong for you. Not good odds.8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator. -
Re: "Solar package special"Arkansasoffgrid wrote: »I responded to that post but it apparently got lost, sorry about that.
No, we're sorry about that. There have been forum issues with the upgrade.The specs on this package are actually 20-30% greater than what my load calculations are. But with a panel degradation of 20% over 25 yrs I should still be ok yrs down the road. Would rather buy a little "extra" now, than come up short at the end of the life cycle.
Panels do not degrade 20% over 25 years. That's an old idea that seems totally inapplicable to modern panels. In 25 Years the panels will be out of warranty and probably be replaceable by much better panels at relatively lower cost (if things keep going the way they have been) if they need replacing at all.
You still haven't said how many Watt hours per day you expect to use or what the total maximum Watts at any given time may be. This information is critical to getting the right equipment. Get yourself a Kill-A-Watt meter and start measuring each and every thing you'd use in "real life" situation. -
Do you need to be off grid? Are you just trying to fix your electric costs? How about Grid tie? Or Hybrid Grid tie? Or even the new SMA grid tie inverters that have a hot plug when the sunshines? Batteries are a huge expense and maintenance item for a viable system.
Give us a hint as to your motivation. -
Re: "Solar package special"solar_dave wrote: »Do you need to be off grid? Are you just trying to fix your electric costs? How about Grid tie? Or Hybrid Grid tie? Or even the new SMA grid tie inverters that have a hot plug when the sunshines? Batteries are a huge expense and maintenance item for a viable system.
Grid tie not really an option, too far from service and was given a quote of about 30,000 reasons to try solar off grid. $1 per reason.8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger, 4590w Canadian Solar panels. Honda EU2000i generator. -
Re: "Solar package special"Arkansasoffgrid wrote: »Grid tie not really an option, too far from service and was given a quote of about $30,000 reasons to try solar off grid.
It is a good motivation.
Usually a good system is designed like this:
1. Determine loads
2. get battery to carry those loads for 2 to 3 days
3. get solar system to charge the needed battery
4. get generator to back up the solar system.
This gets the best system for your needs and gives the lowest possible cost structure. -
$2.60 a watt without batterys doesnt sound like much of a deal. Our system was around $5 a watt, everything included. Thats NZ dollars, with exchange rate and all the crap import dutys and sales taxes here youd be looking about half that in USD. So what exactly was the attraction again?
It might be a bit of a learning curve figuring out all the parts if you DIY, but youll pretty much have to do that anyway with this "kit", to make sure you get it right.1.8kWp CSUN, 10kWh AGM, Midnite Classic 150, Outback VFX3024E,
- 628 Discussion Forums/Café
