Automatic Generator Start
lazza
lazza Solar Expert Posts: 336 ✭✭✭
HI
Well I've got the lovely job of having to install an automatic generator strat to a 20kVA diesel generator.
Currently it just has a key start with 3 positions: Battery, Glow Plugs, Ignition (see pictures)
As I understand the inverters (Victron Multiplus 5000) send a simple on/off signal from a programmmable relay.
I need to know what kind of electricial apparatus to install at the inverter to respond to the inverter signal??
Larry
Attachment not found.Attachment not found.
