Ideas for 12v systems if I do a 24v solar system in my RV
unyalli
Solar Expert Posts: 121 ✭✭
I want to do a 24 volt system so I can use the Magnum MSH4024M Hybrid inverter instead of the MSH3012M. The question is how to power the existing 12 volt stuff.
1) Use an MPPT solar controller to keep my existing group 27 Interstate battery charged off my GC2's?
2) Use a Samlex SDC-30 24VDC to 12VDC converter?
Other ideas?
Jeff
Other ideas?
Jeff
Re: Ideas for 12v systems if I do a 24v solar system in my RV
For heavens sake dont let your 12v gear dictate your systems battery voltage. Battery voltage is determined by the size of your system, peak demand and cable lengths.
These days down conversion is trivial. Ive posted extensively here on dc conversion options.1.8kWp CSUN, 10kWh AGM, Midnite Classic 150, Outback VFX3024E,
Also seriously consider what you have that REALLY needs to be 12v.
Many times it is cleaper in the long run to just eliminate the 12v stuff and replace it with 110v stuff.Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html -
I just had an inexpensive 24v to 12v converter die on me. I did have a backup mppt controller i wired up and it is dping good. Point being plan for failure. Mppt controller needs a battery while converter can work without one.
Get good components. When my converter died is was passing 24v to the 12v system. Shurflo pump lived but a few led lights got burnt up. One was on for maybe 10 minutes when it got hot enough to melt the solder joints.
Now trying to figure out correct mppt setting as battery will be in constant float 24/7. A bit different than using in a solar application which has limited run time.
Animatt -
Zoneblue your off grid page is excellent, thanks.Ive posted extensively here on dc conversion options.
Jeff -
Re: Ideas for 12v systems if I do a 24v solar system in my RVI just had an inexpensive 24v to 12v converter die on me.
I've found the Victron Orion 25 amp DC-DC converter with adjustable output. I believe this is not a cheep converter and if I use it in conjunction with a 12 volt RV/Marine battery this could be the way to go. Setting it's output at around 13.2 would be float and not over charge the battery like the Samlex 13.8 would. With a battery in the mix I would have surge capacity and if the Vic died I would still have 12 volt backup.
Jeff -
Thanks. Try search term 12v eg:
http://forum.solar-electric.com/showthread.php?21527-12-volt-transformer
http://forum.solar-electric.com/showthread.php?21224-Advice-on-small-off-grid-system-for-mountain-cabin/page3
http://forum.solar-electric.com/showthread.php?21587-What-do-I-need-to-power-my-project-12V-DC-2A-draw-24V-5A-draw
http://forum.solar-electric.com/showthread.php?21427-drawing-12v-from-24v
http://forum.solar-electric.com/showthread.php?21056-Stabilizing-voltage-for-LED-Lighting
http://forum.solar-electric.com/showthread.php?22262-Proposed-System-1000W-Advice-Needed!1.8kWp CSUN, 10kWh AGM, Midnite Classic 150, Outback VFX3024E,
