SW4024 Equalizing settings
stmar
Solar Expert Posts: 373 ✭✭✭
I have a Trace SW4024, grid tied, solar, with 12 volt AGM batteries and do not want to "equalize" them. What menu items do I change to accomplish this? Now I have the Equalization process set to the same voltage, 28.8, as my Bulk setting and also have it at the same duration, 2 hours. Since they are the same will those settings nullify the Equalization process or do I need to set the duration and voltage to different values? The 28.8 volts and 2 hour duration are factory default settings for both Bulk and EQ.
Re: SW4024 Equalizing settings
better that you set EQ to the float value, that should be the lowest V rate.
Also, why not set the time to the minimum available.
If there is an automatic EQ, make sure that this is set to manual. FWIW, VicOff Grid - Two systems -- 4 SW+ 5548 Inverters, Surrette 4KS25 1280 AH X2@48V, 11.1 KW STC PV, 4X MidNite Classic 150 w/ WBjrs, Beta KID on S-530s, MX-60s, MN Bkrs/Boxes. 25 KVA Polyphase Kubota diesel, Honda Eu6500isa, Eu3000is-es, Eu2000, Eu1000 gensets. Thanks Wind-Sun for this great Forum. -
I took both suggestions just to be safe and set the voltage to the Float, 26.8 and I was able to set the EQ duration to zero so that should nullify the EQ process. Just wanted to see what other people were doing, the documentation was a little foggy to me on EQ. Most of the dialog had to do with generators and I do not have one in my system. Thanks for the input.
