Tri-mtric tm-2025rv p7 - l3 settings help.
Joedog11
Registered Users Posts: 24 ✭
First I would like to thank everyone for the help I got in setting up my system, It is working great.
Here is a little about my batteries,
(2) 8L-16 Deka 6V 370 ah, Group 16, Normal volts 6 ea. 12 volts, Capacity at c/100 420 Ah, Bulk charge stage 30% of C20 1.75 vpc Max Time (Hr)= Ahr x 1.2 / Avg. Current (A)-voltage limit equal to "Absorption(Regulation) Stage" limits, Absorption stage 2.40 -2.45 vpc Charge until change in current<0.10A per Hr / Max Time 12 Hr, Float 2.30-2.35vpc No time Limit.
So, How would I set the following?
P1- 14.10, P2-8, P3-420, P3 Through P6 my choice, P7-L3, P10-95, P11-Sh.H 500A, P12-On, P13-10.5 P14-0.5, P15 Though P18 Not in use at this time.
Are the settings that I have set up right or do I need to change any. I would like some input so I don't destroy my batteries.
Thank you for the help.
Re: Tri-mtric tm-2025rv p7 - l3 settings help.Are the settings that I have set up right or do I need to change any. I would like some input so I don't destroy my batteries.
The important settings are the charging parameters of your two chargers (morningstar & xantrex). The trimetric doesn't have any control of the charging process.
So, As long as my Dip switches are set right on my TriStar I should be good with it. On my Xantrex with xanbus (SCP) I have been getting a DC over current fault when my solar charge has a full charge on my batteries. I must have a wrong setting on my xanbus then. I will have to check it out.
Thank you vtmaps. -
Re: Tri-mtric tm-2025rv p7 - l3 settings help.So, As long as my Dip switches are set right on my TriStar I should be good with it.
Trust (your TriStar), but verify. You can use your trimetric to "audit" what the other electronics are doing. That's one of the things I like about the trimetric... it can't do anything to your system... it just lets you know what everything else is doing.On my Xantrex with xanbus (SCP) I have been getting a DC over current fault when my solar charge has a full charge on my batteries. I must have a wrong setting on my xanbus then. I will have to check it out.
Do you mean over "current" fault or over "voltage" fault?
I meant over voltage. redid some settings and every thing is working. No more faults.
Thanks again. All you guys that have helped me set this system up ROCK.
