Designing 6kw System Grid Tie MicroInverter Question
KozmoK
Solar Expert Posts: 42 ✭
I have found the markup on local solar companys equipment is huge, and found a good deal after many days of searching on 250w panels.
I want to use Enphase M215 or M250's.
My question is. If I am using 250W panels and I am using the M215's I am limited to 215 wats
so a 24 panel 250w system is 6kw but with the M215's its really 5160. Is it better to use the M250's and get the true wattage out of the panels? They are about $40-50 more then the M215's (which will be about $1k difference in my setup). The difference is 840w.
I feel like I can buy cheaper 230w or 240w panels if I use the M215's to yield the same results.
Also my last question is - will this forum allow a recommendation of a local installer in North Peoria/Phoenix area?
EDIT: I am in no way attempting to install this my self, nor apply for permits myself. I will be paying a contractor to do all that
Re: Designing 6kw System Grid Tie MicroInverter Question
Welcome to the forum.
The first thing you have to understand is that a 250 Watt panel is not going to produce 250 Watts even on a 250 Watt inverter. The average output through hours of good sun is going to be more like 193 Watts. Yes, it's that bad. So whereas the 250 Watt inverter will allow up to the maximum output of the panel and the 215 Watt panel will limit that maximum, you will not actually see that much difference between the two because the panel will rarely if ever hit is rated output. It is quite common to put a 'larger' panel on a 'smaller' inverter in order that the inverter may operate near its maximum for a longer time throughout the day.
So in essence your twenty-four 250 Watt panels is a 6000 Watt array, and no matter what inverter set-up you use (including central type) its averaged output will be about 4.6 kW over the hours of good sun (about 5 where you are) or 23kW hours per day.
Plug your array sizing into PV Watts http://www.nrel.gov/rredc/pvwatts/ along with the other relevant data and see how changing certain aspects of it affects total harvest. -
Thank you so much for your reply. I understand now
This totally changed my design. I think I will buy the 240w panels and the M215's. The money saved that I was prepared to spend on the M250's It will be be best served buying a few extra 240 panels and Inverters to make up for the small loss.
I tried the link you gave, I guess the calculator service is down at the moment giving a error when trying to use it. I will try it again tomorrow.
Thank you again.
Koz -
I think your decision to go with the 240W modules paired with the M215's is the way to go. You are definitely maximizing your inverters potential. The maximum power you will see from your M215's is going to be in the 227W range. Depending on the price difference I would not hesitate to go with the 250W modules, depending on your orientation and tilt the modules will occasionally "clip" under ideal producing conditions ie. bright clear cold winter days but most of the time you will get the extra power. -
I believe you have to use only Enphase approved panels to keep the UL Listing legal.
Go to the Enphase Website and see if those panels are approved.
Re: Designing 6kw System Grid Tie MicroInverter QuestionI have found the markup on local solar companys equipment is huge, and found a good deal after many days of searching on 250w panels.
<snip>
We have members and member/installers in that area, perhaps they will weigh in.
Many installers do a lot more than sell and install systems... they often navigate the permit and incentives process. They know the idiosyncrasies of the local inspectors. Of course you get to pay for their experience when you pay their markup. We've had quite a few folks start out on their own and regret the decision to do so when they can't pass inspection.
Have you considered the likely problems you might see due to putting electronics in the incredibly hot under solar panel environment in Phoenix? I know Enphase will warranty it but why spend more on microinverters when there is this real risk?
By the way how much markup is there in your business? You ought to see the markup the unionized utilities charge. They take 3 cent, subsidized coal-fired power and sell it to us for 12.5 cents plus tax. -
Re: Designing 6kw System Grid Tie MicroInverter QuestionI believe you have to use only Enphase approved panels to keep the UL Listing legal.
Bill, where are getting this information ?
boB -
Re: Designing 6kw System Grid Tie MicroInverter QuestionBill, where are getting this information ?
boB
http://enphase.com/wp-uploads/enphase.com/2011/11/Enphase_Module_Compatibility_List.pdf
Thanks for the info guys! Still in need for a local installer in Peoria AZ -
Yes I understand its super hot here, lived here my whole life in the sun. If they are warrantied for 25 years, then I will get a replacement from them. Maybe keeping one spare for these occasions. I like the idea of monitoring the output per panel like enphase does its pretty slick. If one goes out I will know instantly, and I will be able to pin point exactly which one.
I am getting two more local equipment and install quotes this week. If its within a reasonable markup margin I will just go with them and not hassel with project managing myself. But the two quotes I've gotten so far, they are marking their panels and inverters up $50-60 more per then a internet quote I got on the same exact models.
Thanks again everyone for your time.
I am not sure what your point is about the markup.Have you considered the likely problems you might see due to putting electronics in the incredibly hot under solar panel environment in Phoenix? I know Enphase will warranty it but why spend more on microinverters when there is this real risk?
Hmmm... Either the requirements have changed or I am mistaken. There is a compatibility calculator for solar panels on Enphase modules (says European on website, but none of the documentation says this is only for European installations).
So--Panels just need to meet the Enphase/UL requirements, but panels do not have to be "pre-approved" or approved by Enphase.
Maybe in phoenix, the temp reduces the panel output but in northern NH I see my central inverter clip frequently on clear cold days as the panels are putting out more than the rated output. -
Re: Designing 6kw System Grid Tie MicroInverter QuestionHmmm... Either the requirements have changed or I am mistaken. There is a compatibility calculator for solar panels on Enphase modules (says European on website, but none of the documentation says this is only for European installations).
I think they just don't want you to blow up their inverter. All GT inverters have to limit output power to ratings but put too much PV on it and it will heat up too much and then shut off.
Notice they don't say this is to keep the UL listing. They are already listed.
That's why they let you pick your own. Now, "AC modules" may be a different story but even then, maybe strictly not ?
boB
