Need a Roof Top Single Axis Tracker System
SolarPowered
Solar Expert Posts: 626 ✭✭✭
Make a long story short. One of my clients has to reduce system size because of the setbacks. So now I am window shopping for a solar tracker single axis for an 18* pitched flat roof and the system needs to meet a minimum of ISO, UL/ETL would be a nice add to get it through the building process.
Any recommendations?
Re: Need a Roof Top Single Axis Tracker System
here is a commercial one http://arraytechinc.com/commercial/duratrack-hzla-comm/
see discussion here http://forum.solar-electric.com/showthread.php?21189-Solar-Array-Mounting&highlight=tracker
Re: Need a Roof Top Single Axis Tracker SystemSolarPowered wrote: »Make a long story short. One of my clients has to reduce system size because of the setbacks. So now I am window shopping for a solar tracker single axis for an 18* pitched flat roof and the system needs to meet a minimum of ISO, UL/ETL would be a nice add to get it through the building process.
Be advised that tracking systems are far heavier than fixed systems. Mind your psf. -
I know, the roof meets the structural requirement 8X8 beams 16" on center.
I have an engineer ready to sign off on it that works wiht myself and my client.
All the new setbacks are killing my installations!
- 230 Forum & Website
