Shunt needed?
I have an outback FX2012 inverter protected by a Xantrex 250 amp circuit breaker. The manual for the breaker shows that an MK 500-50 DC shunt is needed, however searching through the Outback documents I can't find any reference to the need for a shunt. Is it internal to the inverter and not necessary, or do I need to install one in the negative input to the inverter? Not really understanding it's function other than regulating current somehow, I can't figure out if it's necessary in this application.
Thanks.
Thanks.
Re: Shunt needed?
Jeff
You do not need a shunt to limit current to the inverter. Shunts are mostly used to measure current into and out of the battery bank. They are used in conjunction with a meter.
Hope this helps
Larry
- 234 Forum & Website
