Absorption Time
Re: Absorption TimeOn full charges, I run absorption at 64V to the point where I belive SG is full. Takes 5-7 hours of absorption. On Nov 23 it took 6 hours 40 minutes. You can call it equalization.
Looks similar to what you're doing
Hi North,
I'm fortunate to have pretty regular longish amounts of sunshine. In fact I haven't used the generator in 4 months (er...that's right I can't use it because it's still at the dealership broken
On your regular charge cycles what are your Absorb times? Are they also ~6 hours using sun + then genny?
If on Nov 22 you charged to 71% SoC what was your SOC reading the next morning? Must have been low.
I absorb at about 59.3V (to 59.6V) typically. This helps to slow down Trojan's or Outback's diminishing returns.
Still don't know which bit of gear to blame. Maybe it's me
Outback Flexpower 1 (FM80, VFX3048E-230v, Mate, FlexNetDC) 2,730watts of "Grid-type" PV, 370 AmpHrs Trojan RE-B's, Honda 2000 watt genny, 100% off grid. -
Re: Absorption TimeOn your regular charge cycles what are your Absorb times?
Daily? Zero. It goes to 58V and stops. I look at it as not doing absorption.If on Nov 22 you charged to 71% SoC what was your SOC reading the next morning? Must have been low.
Depends on the weather. They discharge more in the cold, less in warmer weather. Lately a typical nightly drop has been about 30% (200AH), so that day it probably was somewhere around 40% SoC next morning. Theoretically, my cycling is between 20% SoC and absorption, but in reality it doesn't go below 30-40% often. It only did that, may be, 5 times since September.Still don't know which bit of gear to blame. Maybe it's me
Definitely Trojan. I believe their batteries are designed for backup systems where you can do long charges from the grid. Not good for off-grid. Not in the North anyway. The only hope that they will last as long as advertized. -
Re: Absorption Time
I'm not off grid, but since I'm using off-grid batteries, I cycle them every other sunday late afternoon through monday mid morning (by flipping off the grid circuit breaker). I've been noticing longer absorption times as the weather gets colder.
- 234 Forum & Website
