outback vfx 3524, I cant get to the password or setup screen
kip martin
Registered Users Posts: 7 ✭
Sorry you guys but I am trying to learn
I am reading the manual , it says pressing and holding first two soft keys will bring up the main menu screen with sum status setup adv. When I do that I get a screen that says In , out, aux:off and MPPT bulk. I want to charge my batts with my generator but I see that I need to find the screen that says FX, CC, DC, Mate , I have never seen that screen though I have scrolled around looking for it. My mate is an outback flexmax and while I am on the screen that says In , out, aux:off and MPPT bulk and I press the 1st soft key I get a screen that says charger, aux, light, EQ, Misc., Advanced , logging , stats, and below that I have navigation arrows and an exit and go button. When I press go for advanced I get Absorb time which right now is set to 1 hour. ( is that right?? )
Anyway If someone can help me find my way to the FX, CC, DC, Mate screen I would be grateful.
Pura Vida
Pura Vida
Re: outback vfx 3524, I cant get to the password or setup screen
You have never seen this screen ?? Hold the two left key's. you do have to do them both at the same time and release together or it switch to something else. From there setup >FX> Input . I don't have a flex max , so have no clue.
Attachment not found. -
No I have never seen that screen. How do I find that screen? My mate always has the in, out aux. and MPPT bulk screen showing -
That is a sum/status screen, There is a way to change whats displayed, but you should be able to get to the main screen with the two key push.
NOTE: Pressing and holding the two lower left keys at the same time will always bring up the
MAIN screen. Pressing one key sooner than the other may lead to a different screen.
Here is where your trying to get to. Again Grid or Gen are the same unless your using a AGS.
Re: outback vfx 3524, I cant get to the password or setup screenkip martin wrote: »........ My mate is an outback flexmax and while I am on the screen that says In , out, aux:off and MPPT bulk and I press the 1st soft key I get a screen that says charger, aux, light, EQ, Misc., Advanced , logging , stats, and below that I have navigation arrows and an exit and go button. When I press go for advanced I get Absorb time which right now is set to 1 hour. ( is that right?? )
Pura Vida
What do you mean by "My Mate is an Outback Flexmax....", do you have a separate Mate as shown by the first picture in Blackcherry04's post #4??
(Note : yours maybe black in colour)
It sounds like you are using your FM60/80 ?
- 628 Discussion Forums/Café
