High voltage DC circuit breakers
lazza
Solar Expert Posts: 336 ✭✭✭
HI
I wondered if anyone knows of any very high voltage DC circuit breakers? I could only find midnite solar circuit breakers up to 600V. It's for a grid-tie 800V DC system.
Maybe it's not necessary to put them in and just go straight to the inverter? http://www.aros-solar.com/en/inverter/solar-inverter-singlephase-sirio-evo-3000
Larry
Larry
Re: High voltage DC circuit breakers
I'll suggest you ask the company selling the 800 Volt equipment where to get the circuit protection for their stuff. -
If all you are looking for is over current protection you would be much better off using touch-safe fuses.
http://www.midnitesolar.com/productPhoto.php?product_ID=277&productCatName=Fuses/%20Fuse%20Holders&productCat_ID=22&sortOrder=3&act=p -
HI Thanks
yes, that's what the inverter supplier recommended too
- 621 Discussion Forums/Café
