Solar Array Mounting
Re: Solar Array MountingDave Sparks wrote: »I see that you have changed you opinion on pointing an array up in diffuse light.
Dave, correct me if im wrong but you seem to be promoting the use of this east west tracker. Heres your chance to put some curves up to demonstrate the strength of it. I for one am interested. Does it make up in am and pm for the midday loss? Your point about extending the length of the charging day is well made, but only useful for certain applications, like grid tie FIT.
Ggunns point that optimising for the optimum sun is better strategy for overall harvest numbers, also featured in my own decision making.
PS. How hard would it be to tilt the north south axis to latitude? I suppose if you are high latitudes its going to make the thing a huge sail. Break it into small sections and tilt them seperately, like this:
But if obviously if you google image search solar pv farm, 99% of the images are fixed tilt. Better number crunchers than i have made their own minds
https://www.google.co.nz/search?hl=en&site=imghp&tbm=isch&source=hp&biw=1024&bih=501&q=solar+pv+farm&oq=solar+pv+farm1.8kWp CSUN, 10kWh AGM, Midnite Classic 150, Outback VFX3024E,
Dave's customers are (usually?) off grid systems and Dave really likes the longer day for recharging batteries (more hours at lower average current give him longer battery life--If I remember earlier discussions).
And pumping grease in the Zerk fittings once or twice a year is the usual tracker maintenance.
Re: Solar Array MountingDave's customers are (usually?) off grid systems and Dave really likes the longer day for recharging batteries (more hours at lower average current give him longer battery life--If I remember earlier discussions).
Maybe the option of a "virtual tracker" would be of benefit. Extra panels required however no maintenance and more charging hours, see a discussion at :
http://forums.energymatters.com.au/solar-wind-gear/topic5505.html
The second page has some plots showing power outputs.
regards,
SandyP -
-Bill"we go where power lines don't" Sierra Nevada mountain area
Re: Solar Array MountingDave, correct me if im wrong but you seem to be promoting the use of this east west tracker. Heres your chance to put some curves up to demonstrate the strength of it. I for one am interested. Does it make up in am and pm for the midday loss? Your point about extending the length of the charging day is well made, but only useful for certain applications, like grid tie FIT.
https://www.google.co.nz/search?hl=en&site=imghp&tbm=isch&source=hp&biw=1024&bih=501&q=solar+pv+farm&oq=solar+pv+farm"we go where power lines don't" Sierra Nevada mountain area
The thing with airmass, is that when the sun is low on the horizon, the insolation falls off dramatically, regardless of angle of incidence. Any kind of tracker primarily enhances mid morning, mid afternoon performance.
SandyP, i have seen those virtual tracker curves, and thats why im keen to see curves for Daves east west single axis tracker.1.8kWp CSUN, 10kWh AGM, Midnite Classic 150, Outback VFX3024E,
Re: Solar Array MountingThe thing with airmass, is that when the sun is low on the horizon, the insolation falls off dramatically, regardless of angle of incidence. Any kind of tracker primarily enhances mid morning, mid afternoon performance.
SandyP, i have seen those virtual tracker curves, and thats why im keen to see curves for Daves east west single axis tracker."we go where power lines don't" Sierra Nevada mountain area
I believe this is the product Dave Sparks is referring to:
http://arraytechinc.com/commercial/duratrack-hzla-comm/
http://arraytechinc.com/wp-content/uploads/NEW-DuraTrack-HZLA-Datasheet.pdf
Claims an improvement of 25% over fixed arrays.
But again, Dave is not saying this is more cost effective vs fixed arrays--It allows him more hours per day of significant current flow to charge the battery bank (and support day time loads).
From what little I have learned here about lead acid batteries, having more hours of current to complete the charging of the battery bank (and delay using batteries in evening/morning times)--Is not a bad thing.
The above will track +/- 45 degrees from "flat". For folks in higher latitudes--It may not be the best option for winter use where the sun stays closer to the horizon.
It does look like a simple/rugged system with fewer parts that can be mounted close to the ground for servicing (one actuator can move an relatively large string of panels).
As I always say, a paper design check before spending money. I would like to see a planning tool that would report on the East/West tracking ability (version of PV watts or similar--probably something out there).
Hmm... Looks like single axis tracking with Azimuth set to Zero Degrees should do it with PV Watts. For San Francisco, 4kW array, 0.52 eff:"Station Identification"
"City:","San_Francisco"
"State:","California"
"Lat (deg N):", 37.62
"Long (deg W):", 122.38
"Elev (m): ", 5
"PV System Specifications"
"DC Rating:"," 4.0 kW"
"DC to AC Derate Factor:"," 0.520"
"AC Rating:"," 2.1 kW"
"Array Type: Fixed Tilt"
"Array Tilt:"," 37.6"
"Array Azimuth:","180.0"
"Energy Specifications"
"Cost of Electricity:","12.5 cents/kWh"
"Results"
1, 3.62, 216, 27.00
2, 4.59, 250, 31.25
3, 5.22, 318, 39.75
4, 6.11, 356, 44.50
5, 6.36, 382, 47.75
6, 6.47, 374, 46.75
7, 7.01, 418, 52.25
8, 6.67, 397, 49.62
9, 6.62, 379, 47.38
10, 5.41, 321, 40.12
11, 3.87, 222, 27.75
12, 3.35, 201, 25.12
"Year", 5.45, 3833, 479.12"Station Identification"
"Elev (m): ", 5
"Array Type: 1-Axis Tracking"
"Array Tilt:"," 0.0"
"Results"
1, 2.99, 177, 22.12
2, 4.30, 238, 29.75
3, 5.63, 351, 43.88
4, 7.51, 451, 56.38
5, 8.69, 541, 67.62
6, 9.09, 542, 67.75
7, 9.81, 602, 75.25
8, 8.60, 526, 65.75
9, 7.45, 438, 54.75
10, 5.29, 320, 40.00
11, 3.31, 191, 23.88
12, 2.70, 159, 19.88
"Year", 6.29, 4535, 566.88
Looks very nice for summer--During winter, if I did this correctly, I would get less power from the one axis East/West tracking array...
Fixed Array tilted to Latitude for San Francisco, Sunny day (I think) for 12/23/1974
1974
12
23
07:00
0
1974
12
23
08:00
9
1974
12
23
09:00
710
1974
12
23
10:00
1270
1974
12
23
11:00
1504
1974
12
23
12:00
1747
1974
12
23
13:00
1599
1974
12
23
14:00
1262
1974
12
23
15:00
1423
1974
12
23
16:00
881
1974
12
23
17:00
180
1974
12
23
18:00
0
Total WH
10585
One Axis Array flat for San Francisco, Sunny day (I think) for 12/23/1974
1974
12
23
07:00
0
1974
12
23
08:00
76
1974
12
23
09:00
893
1974
12
23
10:00
1149
1974
12
23
11:00
1048
1974
12
23
12:00
962
1974
12
23
13:00
889
1974
12
23
14:00
821
1974
12
23
15:00
1193
1974
12
23
16:00
1000
1974
12
23
17:00
410
1974
12
23
18:00
0
Total WH
8441
If I could tilt the axis to Latitude--It appears it would generate 10-20% more power in winter...
I had a customer in the Dallas area who had me looking at single axis trackers. With the axis tilted at latitude it would have been worth it if we could have used the cheapest tracker, but that one was horizontal only. The ones with a tilted axis were much more expensive. -
phoned the Co. and can add :
Smallest array design (domestic) is for 4Kw Array
Uses 1/15 hp motor, unable to tell me surge load
Daily 20Whr per day
Cost > $3000, shipping to Canada $500+
smallest member of axis is ~27 feet long.
Re: Solar Array Mountingwestbranch wrote: »phoned the Co. and can add :
The "virtual tracker" option may be better/cheaper and may fit on a suitable roof. -
Daily 20Whr per day
Bill, I sent your data (thanks BTW) to my contact in Engineering and will see if they have time to comment. I liked your SF comment on the sunny days, "I think"."we go where power lines don't" Sierra Nevada mountain area
Re: Solar Array MountingCariboocoot wrote: »That would depend on exactly what the compound is and its resulting electrolytic characteristics.
As it is you'll find the industry does have standards for connectors used with various types of PT lumber. Any place that sells it should be able to advise you on what's right for use with #1, #2, #3 (most common), #4, and #5 (marine grade). Note I said "should", not "absolutely will". :roll:
Before the change in PT lumber there was a standard, listed in the specifications of any job I had to use it on. It was stainless or hot dipped galvanized, hot dipped worked very well. The new stuff is of course different, but the engineers surely, somewhere have an opinion on the fasteners. I would by all means only use ground contact lumber, in air and ground, and any good rubber type compound ( truck/tractor inner tube??) between the aluminum and wood should solve some problems.
- 244 Forum & Website
- 653 Solar Water Pumping
- 628 Discussion Forums/Café
