Problem with sma grid guard code
maskani
Registered Users Posts: 7 ✭
Dear Sir
I have bought two inverters from SMA,
one SMC 10000, and one SI 5048.
So i want to setting up a grid tie/off grid (backup) system. so i called to SMA retailer in my country. i asked a grid guard code to change the thresholds of the SMC 10000.
now i have a personal access code, but my sunny webbox interface has not any grid guard symbol to insert my access code.
in addition i have a sunny webbox (not sunny webbox with Bluetooth), please let me know how to use my personal access code in order to change thresholds of the SMC 10000.
it should be noted that the message "changing failed" is appeared when i try to change without using personal access code (in installer mode)
regards
regards
Re: Problem with sma grid guard codeDear Sir
regards
I have always done this with a laptop computer connected to the serial port of the inverter through the SMA interface cable. -
gfdhI just got my email with my personal code. I have the 5000TL-US. I am also letting the Summy Portal access my site vis the web. How do I make use of the codes to change my parameters when I am off-grid? Do my inverters come with bluetooth? Do I unplug the access point from the inverter and connect to a windows p.c. with Sunny Explorer? Thanks in advancehybrid: two xw6848 pro with four mppt60, 12 kw pv
17 cell 280ah LiFePO4 storage 14 kw (now at 3 banks) total 40 kw
gridtie: sunny boy sma 2x 5k
gridtie: fronius ag5100 two 5k (only one with 1.5k left) running on fumes
Gateway / Insight Local
