Charging and Discharging Parameters Setting of CC
mnsdall
Registered Users Posts: 11 ✭
Hi guys I hope you are doing very well.
Before I post once my problem and you guys gave me advice and I able to solve my problem thanks a lot for that and hope you did same this time as well thanks
I'm using 150w*4 12v solar array
Conected 2+2 =24v
Gel Battery 150Ah*4, 12v ( http://www.narada-ap.com/index.php/download_file/view/269/95/ )
But using as a 24v bank
And my charge controller ( http://solarsystemsphilippines.com/wp-content/uploads/2012/08/VS3024Nmanual.pdf )
In my area full sunshine time is around 7,8 hr
And now days temperature is 35C'
So now my question is
Where can I set
Charging and Discharging Parameters Setting. you can find on page 21.
Pls have a look battery and CC links page and give me your advice
Thanks a lot.
Conected 2+2 =24v
Where can I set
Thanks a lot.
Re: Charging and Discharging Parameters Setting of CC
Your links need to be fixed... The "..." ellipses are also in the links themselves. They were shortened by a website and when you copy and pasted, you got the shortened links.
Oh thanksYour links need to be fixed... The "..." ellipses are also in the links themselves. They were shortened by a website and when you copy and pasted, you got the shortened links.
Battery
CC
http://solarsystemsphilippines.com/wp-content/uploads/2012/08/VS3024Nmanual.pdf -
I am not sure of your questions... It looks like you have a very nice GEL battery and a standard PWM controller. If you set it for GEL, the defaults are pretty close to what your battery asks for. There is a bit of different naming on the controller vs what we usually use here (I think):
Boost=Absorb charging voltage set point
The battery gives "per cell" voltages... For a 24 volt battery bank, the charging voltage set point would be:
2.4 volts * 12 cells in series = 28.8 volts at 25C charging voltage
And so on... GEL batteries do not like to be over charged, so once you set the charging voltage and float voltage--You should use a good volt meter and make sure that these voltages are not exceeded (on days below 25C, the voltages may increase a bit -- cold batteries need slightly higher charging voltages).
