Readind/understanding energy usage labels.
Arkansasoffgrid
Arkansasoffgrid Solar Expert Posts: 117 ✭✭
Ex. A fridg. label states 365kwh yearly. Is that stating 1000 watts used daily x 365 days, or 1000 watts used every hr "1000w x 24hrs x 365days" ? Just started my off grid load list and needed clarification first. Did my first test using the kill-a-watt meter and only seeing .01kwh for a 13watt cfl after 1 hr.
8-420AH US Battery L-16s, Midnite Classic 150cc, Whiz Bang Jr, Magnum MS4448PAE inverter/charger,  4590w Canadian Solar panels. Honda EU2000i generator.
    BB. Super Moderators, Administrators Posts: 33,745 admin
    Re: Readind/understanding energy usage labels.
    Watch your units... Watts and kWatts are "rates" (like gallons per hour). Watt*Hours and kWH are "amounts" (like gallons pumped).
    Anyway, a refrigerator in a warm room (90F?), not opened very often and not making ice will use 365 kWatt*Hours per year.. .Or:
    • 365 kWH per year * 1/365 days per year = 1 kWH per day = 1,000 Watt*Hours per day
    The "average load" will be:
    • 1,000 WH per day * 1/24 hours per day = 41.7 Watt average load
    If you assume the refrigerator motor is running ~1/3 of the time (20 minutes per your), then the average running load would be:
    • 41.7 watts * 3 duty cycle = 125 Watts when compressor is running
    Frost Free freezers and refrigerators have a heater inside to melt frost off the evaporator (typically runs ~1 hour every 12 hours). That is usually around a 500-600 watt load.
    And the starting current for a typical compressor is around 5x running load:
    • 125 watts * 5 starting current = ~625 VA starting load
    Typically, an Energy Star refrigerator will need around 1,200-1,500 watt AC inverter (and large enough battery bank) to start reliably and run a few other loads (lights, laptop computer, etc.) at the same time.
    365 kW hours yearly? That would be average 1kW hour per day, which is about right for a standard refrigerator these days.
    That would be an average draw of 42 Watts, but refrigerators don't work like that. Since they cycle on and off it probably is on 1/3 of the time and uses about 125 Watts running.
    0.01 kW hours for a 13 Watt CFL in 1 hour is normal: it's 10-ish Watt hours and the light draws 13 Watts so over one hour it should use 13 Watt hours (0.013 kW hours) but the K-A-W does not read such small amounts.
