New Off-grid house
Re: New Off-grid house
Coot, in the last two weeks we have had 226mm of rain. Its done nothing but rain, its a spring thing where we are. (Its also what allows NZ to run its grid using 75% hydro.) I guess for some folk thats a whole years worth of rain, but is quite normal here, not out of the ordinary.
Yet, on only two days did we not float. Dawn rest voltage not below 24.6V those days. I cant tell you the exact SOC, but it was no where near my worry level.
Heres the blackbox daily agregates for that period:date_created classic rev firm plife durbulk durabsb durfloat maxpout maxiout maxvbat minvbat ptoday whtotal whabsb whfloat 16/09/2013 150 4 1370 371.1 3.3 1 7.1 1400 51.7 28.5 24.7 3.6 3790 645 1965 17/09/2013 150 4 1370 374.7 1.1 1 8.6 1391 50.8 28.5 25 0.4 3304 612 2308 18/09/2013 150 4 1370 375.1 1.2 0.5 9.2 953 34.8 28.5 25 0.1 3974 248 3431 19/09/2013 150 4 1370 375.2 3.7 0.5 4 650 23.4 28.5 24.7 0.3 1366 229 440 20/09/2013 150 4 1370 375.5 1.6 0.5 3.8 1111 39 28.4 24.7 2.1 1448 351 609 21/09/2013 150 4 1370 377.6 5.3 0 0 459 17.2 26.6 24.6 1.1 603 0 0 22/09/2013 150 4 1370 378.7 5.8 0.4 4.5 985 34.7 28.3 24.6 2.2 1098 211 643 23/09/2013 150 4 1370 380.9 1.5 0.3 9.8 665 23.6 28.3 25.1 1.5 756 132 923 24/09/2013 150 4 1370 382.4 3 0.1 7.9 460 16.2 28.3 24.9 1.8 903 58 1091 25/09/2013 150 4 1370 384.2 11.2 0 0 363 13.4 27 24.8 1 547 0 0 26/09/2013 150 4 1370 385.2 1.7 0.4 8.6 621 21.7 28.4 25 2.1 998 217 1321 27/09/2013 150 4 1370 387.3 3 0.9 7.4 1367 47.8 28.4 24.9 2.8 1433 916 972 28/09/2013 150 4 1370 390.1 3 1 7.1 1575 55.1 28.4 25 4.7 2358 1300 2763 29/09/2013 150 4 1370 394.8 2.5 0.3 9.3 758 26.6 28.4 24.9 1.5 735 169 933 30/09/2013 150 4 1370 396.3 1.9 0 0 325 12.3 26.4 24.8 0.1 88 0 0
Today is a case in point, been raining all day, controller just went to absorb, barest of shadow, still making 460W on 1800W array. Those days where the controller clicks in and out of sleep all day are very rare, maybe a few per year.
Attachment not found.1.8kWp CSUN, 10kWh AGM, Midnite Classic 150, Outback VFX3024E,
being a real newb myself one of the things i've picked up on reading the forums is that if you want to live (kind of) like you are on grid (which based on your loads it seems you do) then having an inverter with generator support and implementing it properly will save you a lot of worrying about the worst case. Design your system based on nominal loading and if you want to do something above, the generator is there to kick on and support you.
ChrisOlsen has a very good thread and Youtube video on his implementation. -
The problem in VT is we get multiple 2 and sometimes 3 week stretches without usable sun. Last year was particularly bad. I ran the generator 51 hours from Oct 29 to Mar 30. The lowest it's ever been is 35 hrs. What that says is don't try to plan for a week of autonomy. The weather won't cut you a break every 7 days. You still are going to run the generator.
IMO, you've got to have enough battery to start your bigger loads and enough battery for a few days of autonomy. I'm in the buy more panel camp. I'm not sure it's really possible to buy enough panels such that you don't run the generator in winter, but the larger arrays will help minimize generator usage and drive daily loads without using battery in late fall and early spring. If you aren't using AC, there's almost no point in crunching numbers for summer. If you size for winter, you'll have all the juice you want in summer. What to do with extra summer juice is a common question. I put mine into AC and dehumidifiers.
I think the problem with generator support is the time it takes to fire up and warm up the generator (in winter especially). I don't see how it's practical. I can understand using for an oven
where you have an element, but it seems to me that the scenario would not be good for other types of electonics. I would think the big load would starve the other electronics in the house while waiting for generator power. In our older system, we had a washing machine that shut itself off every time the water pump came on. I've got to think generator support would lead to the same type of behavior. So for me, I would be hesitant to install a system that relied on generator support for peak loads.
From my experience, I would go with the most advanced equipment. 48v. Unless you have absoluely no use for split phase, get a split phase inverter. What is your well pump? Avoid 110v->230v transformers. The startup inrush current on them is huge (esp toroidal). Size your inverter for the loads you don't have yet. Nothing like having to buy a new inverter cause you want to add more loads. It would also seem to me that it would be better in terms of equipment lifetime to operate a larger inverter at some percent of capacity versus a smaller inverter at a large percent of capacity. I've noticed on my older sw4024, quality of juice dimishes as load approaches it's rating.
Maybe I missed it, but what do you have for heat and hot water?
IMO, the AC fridge is no brainer and you don't have to go the sun frost route these days. Our 20cuft kenmore w/ ice maker was rated for 1.2 KWH/day but was about 0.75KWH/day when we first got it. I'm certain it's more now after ~5 years, but it still has got to be around 1KWH. The thing with the gas fridge is it's a heat source in summer and produces moisture (heat+moisture=mildew). We had one. Frankly, I'd buy extra panels just so I could have an electric fridge. -
It's a propane hot water heater and a 240v pump. I seem to have read that some pumps are better made for solar and also that we can potentially put in a larger pressure tank. Although how much hassle is it to change the pump in the well?
I've also wondered how efficient and expensive either a) pumping water up above our house (hill) and or b) heating that water with excess sunny days solar would be?
In any case I want to thank everyone for your very thoughtful replies. I'm probably going to have to start a new thread at some point with some specific install questions in the near future. Thanks again. -
Re: New Off-grid houseI've also wondered how efficient and expensive either a) pumping water up above our house (hill) and or b) heating that water with excess sunny days solar would be?
We have a 275 gallon water storage tank on the top of an 18' tower. About once a week, mid-day when I have excess power, I use the well pump to fill the tank. Then the rest of the week the water comes from the tower via gravity feed. I also have a small 12v sureflo pump to give me more pressure from the tank if I need it.
Now, we are in Florida so I don't have to worry about it freezing. If you had a good sized hill next to your house, then you could do the same thing by just placing the tank up on the hill. Maybe even bury it to prevent freezing if that is a concern.Off-Grid in Central Florida since 2005, Full-Time since June 2014 | 12 X Sovello 205w panels, 9 X ToPoint 220w panels, 36x ToPoint 225w panels (12,525 watts total) | Custom built single-axis ground mounts | Complete FP2 Outback System: 3 x FM80, 2 x VFX3648, X240 Transformer, FLEXnet-DC, Mate-3, Hub-10, FW500 AC/DC | 24 x Trojan L16RE-B Batteries 1110ah @ 48v | Honda EU7000is Generator and a pile of "other" Generators | Home-Made PVC solar hot water collector | Custom data logging software http://www.somewhatcrookedcamp.com/monitormate.html -
Re: New Off-grid houseIt's a propane hot water heater and a 240v pump. I seem to have read that some pumps are better made for solar and also that we can potentially put in a larger pressure tank. Although how much hassle is it to change the pump in the well?
We changed our well pump and replaced it with a grundfos slow start. It may have been $1500 with labor. You can change the pump to 110v or DC, but then you are limited to a certain depth and you'll need to upgrade the wire running to the pump. Usually it's just #10 wire for a 240v pump. IMO if you are getting a new inverter anyway, it makes sense to just get a split phase one.
- 231 Forum & Website
