Forum has been hacked - now unhacked. -Bill
Cariboocoot
Banned Posts: 17,615 ✭✭✭
Some idiots have decided to mess with the forum.
I hope all of you have your full security running.
Re: Forum has been hacked - do not use
I am good, put up a Site blocker on FireFox (Block Site 1.1.18 plugin)
BTW A$$holes -
For Firefox, I finally figured out a setting that lets back into the forum:
See: Firefox > Preferences > Advanced > General : Accessibility : [ ] "Warn me when web sites try to redirect or reload the page"
This works for me.
And our friends at NAWS now about the problem and are working on it. "Windsun" retired a while ago and has been taking a well deserved break from all things work related. So, it may take a bit of time for them to get the redirect out of the stylesheet (or where ever it is).
Hang in there guys.
good to see you figured out how to get back in here bill.
as far as we know there are not any viruses associated with the access to the forum as it is a redirect page that is haunting the site right now. -
I curl'd the content and it seems to just be a web page, I don't see any scripting but ...
here is the content issue redirect
</li><li class="restore" id="navbar_notice_2">
<META http-equiv="refresh" content="0;URL=http://www.cadiroig.cat/">
</li> -
That link references a bunch of static crap and a single flash page on YouTube for the music crap. -
Thank you Solar Dave.
I believe Windsun is here working on the problem--So it should be back up and humming soon.
No redirections here. Must've been fixed already. -
Re: Forum has been hacked - do not useNo redirections here. Must've been fixed already.
Yep just checked a curl from the site and it looks better. -
I think I've got it fixed for now. I went into the admin panel because the code I looked at made me think the hacker simply entered a Vbulletin notice that just redirected traffic. I deleted the notice and it seems to be working. If anyone sees an admin that they don't recognize, let me know. We're planning to upgrade to the newest Vbulletin software in hopes that it will prevent whatever exploit the hacker took advantage of.
RickWebsite administrator for Northern Arizona Wind & Sun -
We're back in business!
Thanks to Windsun's magic fingers.
If I still had the Linux machine I would have poked at it myself, but being forced to run Windows I don't trust anything (even with all the precautions I have in place). The re-direct site might have dumped a trojan on people, and I don't mean an L16! -
good here too. great as now we can put this behind us. -
new attack from username upgrade -
You guys are messing up my retirement plans, but looks like Rick fixed it. Basically they somehow inserted some code into the pages for an HTML redirect to a file they added to the site. Not sure what the insertion point was, but since we are upgrading to the new 5.0 version probably don't matter much. -
I did a search for the website name, and apparently they've hacked other websites as well. I don't think there are any viruses or trojans, etc... associated though, according to reviews of the site cadiroig.cat. Also did a scan and it didn't pick up anything on my computer, thank god. Good advice to check notify before redirecting away from the site. -
Re: Forum has been hacked - do not usenortherner wrote: »I did a search for the website name, and apparently they've hacked other websites as well. I don't think there are any viruses or trojans, etc... associated though, according to reviews of the site cadiroig.cat. Also did a scan and it didn't pick up anything on my computer, thank god. Good advice to check notify before redirecting away from the site.
I once got a virus, which came to me through Adobe PDF Reader (which I don't use since), For curiosity, I decided to run a scan with different anti-virus programs. None of them found it. I wrote to companies asking if they want to get a sample of a virus that their software doesn't recognize. Only one responded, but they didn't want the sample. So, these scans aren't worth anything.
I didn't think there was any virus here. But they stole all our brilliant ideas!:grr
Thanks to WindSun!Cariboocoot wrote: »If I still had the Linux machine I would have poked at it myself, but being forced to run Windows I don't trust anything (even with all the precautions I have in place).
One option (there are many) you may want to explore without having to have a dedicated linux machine is to run Knoppix from a CD/DVD or usb flash-key.
I'm doing that right now with Knoppix 7.2.0 (CD version) that I downloaded from a mirror-site so that everything is read-only and in ram. Burn the downloaded image as an ISO file, do not just copy to CD - windows will let you choose this if you double-click on the iso file in windows 7 (3rd party iso burners also available too..) Firefox 21 is already installed along with no-script already included. If you want to run from a usb-key, once up and running from cd/dvd, there is an option to burn to usb which makes it super easy if you prefer to run from a usb key, although you may need to open the bios or startup sequence to do so. I didn't choose to use the "adrianne" version, since that has special needs for blind users (but still awesome for those that do need it. Thank you Klaus!! ).
Just reboot and you are back into windows without having touched anything.
There are many options, but I found that Knoppix was by far the easiest way if one doesn't want to do a full disk installation.
- 616 Discussion Forums/Café
