New connection between stacked solar cells can handle energy of 70,000 suns
RSSfeed
Registered Users Posts: 3,810 ✭✭
Researchers have come up with a new technique for improving the connections between stacked solar cells, which should improve the overall efficiency of solar energy devices and reduce the cost of solar energy production. The new connections can allow these cells to operate at solar concentrations of 70,000 suns' worth of energy without losing much voltage as 'wasted energy' or heat.
More...
More...
Re: New connection between stacked solar cells can handle energy of 70,000 suns
Right: all we need do is put some of that "clear" window-film solar material on top of our regular PV's and ...
Re: New connection between stacked solar cells can handle energy of 70,000 suns...which should ... reduce the cost of solar energy production.
That part is total nonsense.
