Busses
Caveman
Solar Expert Posts: 83 ✭✭✭✭
Re: Busses
Check out a local boat chandlery for Blue Sea products. Lots on line as well. -
Re: Busses
The Blue Sea 2126 bus is probably big enough. It has 6 studs that are 5/16" and are rated at 250A continuous.2020 Watts, 4 Evergreen 120 watt, 1 Eoplly 190 watt; 1 Sungold 200 watt; 2 generic 175 Watt; 4 Rich Solar 200 watt; Victron MPPT 150-45 x2; Victron 24v 3000 watt Multiplus2; 4 100 AH Redodo 24 v Configured to 400@24V -
Re: Busses
Thanks for the help, this is what I ended up getting:
http://www.bluesea.com/products/2723/DualBus_Plus_150A_BusBar_-_5_16in-18_Stud_5_Gang
