system advice needed
blazeddragon
blazeddragon Registered Users Posts: 4
i want to make a system to at 1st run 1 to 2 5v dc fans. these will be used to cool my bearded dragons cage and eventually want to expand the system to cover his cages 121 max w/hr consumption.
fan specs:
5v dc
.1 - .3 a. i used .3 in my calculations
1.3 watts
fan(s) will be on for 12 hours per day.
cage power usage:
2x 23w florescent
1 75w halogen on a dimmer
i thought about using a 6v system to start with then move to a 12v one.
need help with panel choice, wiring, and controller options(if needed).
    Re: system advice needed
    Welcome to the forum B-dragon!
    It is very difficult to slowly "expand" an off grid solar power system... Battery capacity needs to increase. Small charge controller needs to be replaced with a larger one. Larger solar panels may not be compatible with smaller solar panels (need a second, more expensive MPPT charge controller, etc.).
    And, things that run 24x7 frequently use many times more power than those items that take a lot of power but only run a handful of minutes per day (i.e., a laptop computer can use several times as much energy vs a microwave oven that runs a few 10's of minutes a day.
    For AC power, it would be really helpful for you to measure your daily usage (in Watt*Hours or kWH) with a Kill-a-Watt type meter.
    If you want to run these 12 hours per day:
    2x 23w florescent
    • 2*23w + 75w = 121 Watts
    • 121 watts * 12 hours per day = 1,452 Watt*Hours = 1.45 kWH per day
    That is around the same amount of power as a full sized energy star refrigerator would use. That is not a "small" amount of power. If you doubled that (lights, washer, well pump, computer, etc.)--That would be enough to power an entire (very efficient) smallish off grid home.
    The fans are on the other side of the power usage curve:
    • 0.3 amps * 5 volts * 12 hours = 18 Watt*Hours per day
    Or about 1/100th the amount of power as for the lights... Not a very easy system to "scale" from a tiny amount of 5 volt power to a fair amount of 120 VAC power.
  • blazeddragon
    Would it be easier to just power the fans and leave it at that or start with 12v dc fans and go from there or suck it up n just pay the electric company for the 5v fans?
  • NorthGuy
    Paying for fans will probably cost you around $0.60/year. Unless you're interested in learning how to build solar systems, it would be a very good choice.
    It depends on your needs... 120 VAC fans--bypass the whole need for any voltage conversion... You can use batteries+inverter for backup.
    Or 12 volt computer fan on a small battery bank--Other than the battery charger, no need for more electronics/hardware.
    5 volt fans. Usually very small and little air flow (volume). If using Lead Acid batteries, most solar charge controller are a minimum of 12 volts, so you would need another small down converter (like a USB power supply adapter).
    All would work... Just depends on your needs (reliability, fans run in power outage, cost, available equipment, future needs, etc.).
    I think you will find 12 volt battery system a bit more practical and useful for other needs. 5-6 volt system is pretty specific to your loads and you will not find much in the way of "off the shelf" solar hardware (don't know of a solar charge controller that will charge 6 volts of lead acid batteries).
    If you will be having a "larger" backup power system--Many times, just going 120 VAC is going to be the easiest to support (cell phone chargers, easier to send power more than a few 10's of feet, etc.).
    In terms of learning--There are many switching power supplies available now that are much more efficient, especially with greater voltage drops (i.e., 12 volt to 5 volts) vs using the older 3-Terminal "analog" series/shunt type regulators (i.e., for best efficiency, you would want a 6 volt battery to 5 volt fan series regulator).
  • blazeddragon
    using 12v fans would not be a problem, i need to cool a area of ~2'x2'x2x by ~10 to 15 degrees. i think 120vfans would be serious overkill, maybe i'm wrong here. will look more into 120v fans after work tonight.
  • NorthGuy
    Do you want to make it cooler than ambient by 10 to 15 degrees, or do you want to remove heat produced by a lamp (or other heat source)?
  • blazeddragon
    there is a 23w fluorescent bulb on that side of the cage. the other side of the cage has a 75w halogen creating heat along with a 23w uvb bulb. the "cool" side of the tank runs ~10 to 15 degrees hotter than it should. will post a pic of cage when i get home if needed. also going to a grid system is not out of the question, just as of right now it is.
