Bulk charging charger set up
Caveman
Solar Expert Posts: 83 ✭✭✭✭
Things are looking up. Starting to understand this whole solar thing. Remember I said starting. haha
Since this forum is so helpful, I've got another question(s).
My cabin is about 60' from where I have the PV panels, inverter, charge controller, and batteries. I have everything out in a sort-of "dog house" that I built, and I am running AC power from the inverter back to the cabin. My generator is near the cabin, but about 100' from the PV panels.
In order to bulk charge my batteries when the solar is not sufficient, I need to run a separate wire back to the "dog house" from the generator to power my Battery charger, right?
The generator already has a separate cable going to the cabin to power the cabin's AC outlets when the generator is on.
Re: Bulk charging charger set up
Yes: if you want generator AC power in the shed with the inverter is you need another set of wires; you can't "back feed" it along the inverter's AC output.The generator already has a separate cable going to the cabin to power the cabin's AC outlets when the generator is on.
That sounds as though you already have the required wiring in place. If there's an outlet in that shed that's live while the gen is running and the inverter is not, that can power the battery charger. -
Re: Bulk charging charger set upCariboocoot wrote: »That sounds as though you already have the required wiring in place. If there's an outlet in that shed that's live while the gen is running and the inverter is not, that can power the battery charger.
I was confusing, the existing power cable goes to the cabin, not the "dog house". -
Re: Bulk charging charger set upI was confusing, the existing power cable goes to the cabin, not the "dog house".
Then you need another set of wires. -
Yeah I got it, thanks again. I hope you enjoy this, you guys on this site are an invaluable resource to an ignoramus like me. -
You can put the wires from the genset to the dog house, have an internal transfer switch and pre-wired AC battery charger (or even an inverter/charger)--then use the present AC wires to the cabin.
Fire up the genset, the power goes to the AC Battery Charger, and the transfer switch connects the cabin to the AC Generator output (either a manual or automatic transfer switch--your choice).
Sort of depends on how you want to run things (need to go to dog house to monitor battery state of charge... Or put genset near cabin for easy starting and maintenance with AC wiring to both--AC battery charger in dog house; AC power in cabin--with or without transfer switch).
Re: Bulk charging charger set upSort of depends on how you want to run things (need to go to dog house to monitor battery state of charge...
I like the idea of having batteries, inverter, etc in the dog house. I suggest that you run another conduit from dog house to cabin for monitoring and control. You can run wires for battery monitor, inverter control, etc through that conduit. Low voltage monitoring and control wires should NOT share a conduit with your AC power cables.
From what I've gathered, most of this system is already wired up. As such moving the gen and transfer switch to a locale closer to the inverter site may not be as easy as running a new wire set back to the inverter to run the battery charger from. -
Cariboo is right, but I guess that doesn't prohibit me from running some low voltage wires back to the cabin for monitoring.
- 228 Forum & Website
- 618 Discussion Forums/Café
