Smarter Grid Linking Solar Panels May Bypass Utilities
Re: Smarter Grid Linking Solar Panels May Bypass Utilities
Checked out the Heart Trsansverter?
http://www.transverter.com/ -
You know of anyone with one of the Transverters? -
At only ~$12,700 per kit... ouch http://www.transverter.com/smart.html
That "kit" is a 4 kW system with 1,840 W Solar, and batteries.
You have a good setup with what you have but doesn't compare to what this system could/would deliver. What are you comparing it to price wise?
There is no doubt that the product is not cheap, but the functionality is beyond anything I have seen from any other product. -
That is a lot of cash to lay out for a brand new on the street type system. For example I see they are listing Can Solar panels at >$2 per watt, when other good brand panels sell well below that, second hey list 6 12v GEL batteries, that is either a weird voltage or a compound of 3 strings of 24 v, 2 of 36 v or 72 volt ??? = (probably) Custom equipment if not 24v...
4 Kw is a lot to ask from a 12 v system.
They have assumed 5 'good sun ' hours per day to get 9 KWH per day/276 Kwh per month, a fair bit optimistic....
Re: Smarter Grid Linking Solar Panels May Bypass UtilitiesDragonlady5 wrote: »There is no doubt that the product is not cheap, but the functionality is beyond anything I have seen from any other product.
How about this: http://www.sma.de/en/produkte/monitoring-systems/sunny-home-manager.html -
The costing they have on their site is date I believe 3-4 years, and this is just an example/excercise (marketing wise), but that's not the issue, neither is the estimates on Wh.
The HT2000's battery can be anywhere from 12 to 48 Volts (unusual/unique for anything on the market). With 6 x 12 as you said could 24 or 36.
I would put my own system together in any case..
- 227 Forum & Website
- 618 Discussion Forums/Café
