Does a fully charged battery weigh more than a depleted one?
CraigC
Registered Users Posts: 16 ✭
Maybe this thread can be posted under Stupid Questions but.... does a fully charged battery weigh more than a depleted one?
Re: Does a fully charged battery weigh more than a depleted one?
Saving water loss, no.
The material mass is all still there, it's just a difference of whether the sulphor is clinging to the plates (discharged) or still in the electrolyte (charged). -
In theory, yes... E=MC2.
In practice, no--The amount of mass increase due to the increased energy is practically zero.
I think I read that in an article a while ago trying to answer exactly that question.
Of course, there are batteries (such as Zinc-Air) which exchange mass outside of the battery box. Those would have significant weight differences.
Less.
First, as 'Coot said, there will be loss of water during charging.
Second, the volume of the electrolyte increases, so it'll be more buoyacy in the air. When put on scales, it'll weight less.
So, charge your batteries before moving -
I was talking about sealed (VRLA/AGM/GEL/NiCAD/NMHi) batteries. Obviously, any battery that "boils" off moisture and gases, is going to weigh less.
Re: Does a fully charged battery weigh more than a depleted one?Less.
As the volume of the electrolyte increases, it displaces air from the inside of the battery case (for FLA only), so the effective volume of the electrolyte inside the battery will increase even though the outside dimensions of the battery do not change.
And as the material of which the battery is constructed changes from internal heating, the same thing will happen, just not by as great a percentage. And you have to be careful not to let it cool off before you move it. The electrolyte volume change, on the other hand, is chemical. But does the volume of the plate decrease by the same amount? That is a tough one....
An AGM or GEL will only get lighter from the thermal expansion of the battery case.
And I am glad that nobody tried to bring up the mass of all of the electrons that have been forced into the battery (but also out the other side!)SMA SB 3000, old BP panels. -
Why don't you boys run some tests with your bathroom scales and tell us how much difference you see between charged and discharged? -
Re: Does a fully charged battery weigh more than a depleted one?And I am glad that nobody tried to bring up the mass of all of the electrons that have been forced into the battery (but also out the other side!)
But I submit that as the battery chemistry is altered during discharge, the distribution of electrons will throw the batttery off balance, switch polarity, and go "out of phase", with an infinite number of varying batteries across multiple universes, all connected via curved energy from the 'vacuum of space-time. -
If you capture all the hydrogen gas into a large balloon and tie that to the batteries, I would think that the batteries would gradually become lighter. If the balloon is big enough, eventually the batteries would be floating.:p -
Re: Does a fully charged battery weigh more than a depleted one?northerner wrote: »... eventually the batteries would be floating.:p
When it's sunny, mine are floating every day -
after out gassing one is supposed to replace the lost water.
when the volume of an agm or gel battery expands this does not change its weight.
the question matters not anyway as my aching back still says they're just as heavy.:p -
Re: Does a fully charged battery weigh more than a depleted one?But I submit that as the battery chemistry is altered during discharge, the distribution of electrons will throw the batttery off balance, switch polarity, and go "out of phase", with an infinite number of varying batteries across multiple universes, all connected via curved energy from the 'vacuum of space-time.SMA SB 3000, old BP panels.
Re: Does a fully charged battery weigh more than a depleted one?Now you are reminding me of a Tom Swift book I read as a kid. Tom has built a space station, and rather then continually ferry more oxygen up from the surface he puts oxygen atoms into a cyclotron (all good space stations have them, you know) and accelerates them to near light speed to increase their mass. Thereby providing as much oxygen as he can use.
Sort of a reverse-Fantastic Voyage thingy....
- 616 Discussion Forums/Café
