The Tale of Two Inverters
Blackcherry04
Solar Expert Posts: 2,490 ✭✭✭
I have up-grading my Inverter systems year. I have a Xantrex SW 3000 TSW that was carrying all the loads and charging. I bought a Outback GFX to try to take advantage of " Generator Support ", so I split the Busses so they could share the loads. At the same time I decided to buy 18 LED bulbs ( $200 + ) to change set of recessed lights that had a 600 + watt draw. It remained on the Xantrex TWS Inverter. After I changed the bulbs I tested it in the Invert mode, all they did was blink, I think it the crappy dimmer, buy a $22.00 new dimmer, same thing. The lights would never burn steady and had a rhythmic pulse to them. So today I change them to the Outback buss, Steady as a rock, never a blink. So if you think all TSW Inverters as same , you'd be wrong.
Re: The Tale of Two Inverters
Did they blink at ~1 second rate? Was the inverter set to "search mode" looking for >6-10+ watts (typical one AC cycle "pulse" every second)?
I agree that with all of this "new" lighting stuff (CFL, LED, dimmer or not dimmer compatible, new CFL/LED compatible dimmers that still need compatible LED/CFL lamps, etc.)--That there will be problems found along the way.
Re: The Tale of Two InvertersDid they blink at ~1 second rate? Was the inverter set to "search mode" looking for >6-10+ watts (typical one AC cycle "pulse" every second)?
-Bill -
Did they blink without a dimmer?
I have XW6048, and I can see that my dimmed lights change level a little bit when load on the inverter changes (something comes on or off). But I haven't seen that with non-dimmed lights of with dimmers at 100%. -
Re: The Tale of Two InvertersDid they blink without a dimmer?
Re: The Tale of Two InvertersBlackcherry04 wrote: »No way to Know, because they always had a dimmer. It was a old rotary type , 15 years old. The new is a slider.
For testing purposes you could bypass the dimmer and run them full-on. If they still blink on and off something is definitely wrong with the inverter. -
Re: The Tale of Two InvertersCariboocoot wrote: »For testing purposes you could bypass the dimmer and run them full-on. If they still blink on and off something is definitely wrong with the inverter.
And the Xantrex works fine on everything else? If it does, don't be surprised if they find nothing wrong with it.
- 651 Solar Water Pumping
- 611 Discussion Forums/Café
