Emf from neighbour's solar panels
Re: Emf from neighbour's solar panelsYes, and if the ground wire is smaller than #6 you have to put it in some sort of sheath for mechanical protection.
It's driving the 8 foot rod into the ground with every step that's the real hard part. -
Re: Emf from neighbour's solar panelsCariboocoot wrote: »aluminium foil just isn't dense enough to block the radiation.
Would it help if my density was combined with the density of the aluminum foil?
I've often been told that I'm dense, so might that help?
And yeah, that 8 foot ground rod thing could be a real problem
Guys you are being Trolled..... -
Re: Emf from neighbour's solar panelsGuys you are being Trolled.....
Au Contraire! We are merrily Trolling ourselves. :-)SMA SB 3000, old BP panels. -
Looking at the original post--I am pretty sure that this was just a very good job of burying product names on the forum for scammy products in the original post.
I have "broken" the names/links for now.
Bill, me thinks you've hit the proverbial nail right on the head! We got suckered. HahahahaLooking at the original post--I am pretty sure that this was just a very good job of burying product names on the forum for scammy products in the original post.
